Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Can't open HDD drive
I can't get my external HDD to open. I can see it it in my windows explorer but when I try to open it it gives me an error message: P:/ is not accessable. Error performing inpage operations.
it's a seagate baracud 7200.10 HDD in a mobile landisk encasing.
Please help!?
  • snaveevad
    snaveevad Sep 21, 2012
    What causes are responsible for a drive to behave like this?
  • snaveevad
    Had exact same issue with a Seagate FreeAgent Go 320GB, tried Jyothish nv's suggestion and it worked, turned out chkdsk found, deleted and replaced a corrupt attribute. Thank goodness for you folks who still remember and use DOS.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
This won't do any harm, it will fix errors on the disk and try to recover data from bad sectors. It might not solve the problem but it's worth a try. Jyo
Posted on Jun 19, 2008
  • Butch Vincent Isabelo
    Butch Vincent Isabelo Mar 26, 2014
    Yes, it worked! :) It does not turned out to be successful at first because some errors occurred while checking the files. But I re-inserted the device and used chkdsk D: then chckdsk D: /f to fix errors and used again the chkdsk D: /r. A message that the disk have already no enough space came out. I was worried, but when I checked the device, it is already working fine... Thank you very much.
    Yes, it worked! :) It does not turned out to be successful at first because some errors occurred while checking the files. But I re-inserted the device and used chkdsk D: then chckdsk D: /f to fix errors and used again the chkdsk D: /r. A message that the disk have already no enough space came out. I was worried, but when I checked the device, it is already working fine... Thank you very much.ment
Posted on Sep 21, 2012
  • snaveevad
File record segment 32 is unreadable.
file record segment 32 is unreadable.
Posted on Jan 07, 2009
How do i format hard disk drive
To format an external drive (HDD) in Windows:
1. Plug your drive into the computer and, if necessary, into a wall outlet.
2. Open Windows Explorer, click the "Computer" section in the sidebar and find your drive.
3. Right-click on the drive and choose "Format."
4. Under "File System," choose the file system you want to use. See the above section for more details on which one to pick.
5. Give your drive a name under "Volume Label," and check the "Quick Format" box.
6. Click "Start" to format the drive. You'll get a notification when it's done (it should only take a few seconds).
May 11, 2014 | Carrozzeria CYBER NAVI HDD AVIC-VH009MDG
I installed a second WD My Book, after the first one inexplicably filled up too quickly. Now the second one has inexplicably filled up also. What could be causing this?
The most logical reason for this problem to occur is because you're storing too many files in the ROOT of the external hard disk drive (HDD). The Windows file system can only manage a limited number of files (about 500) in the root of ANY drive. It is better to store those files in a FOLDER on the drive; Windows can manage an infinite number of files IF you store them inside a folder. Let's see if we can resolve this step-by-step:
1. Open Windows Explorer and navigate to the external HDD (drive E:, drive F:, drive G:,or whatever letter it has on your system).
2. If the external HDD does NOT have a name (such as "WDMyBook01", or something else easy to remember), RIGHT-CLICK the letter of the external HDD; Windows will give you the option of creating a NAME for the external HDD.
3. Create a name for the external HDD, you can use any combination of letters or numbers, but NOT MORE than 11 characters in length. By creating a distinct name for your external HDD, you'll have an easier time remembering which MyBook drive has certain files on it. Be sure to do this for BOTH external HDDs.
4. Next, create a new folder in the ROOT of the external HDD; give it a simple SHORT name, such as "Folder01" (no quotes).
5. MOVE ALL OF YOUR FILES from the ROOT of the external HDD into the new folder you just created.
6. In the future, put ALL your files into a folder on the external HDD, so you can avoid experiencing this problem again.
7. As you've probably already guessed, it is also a good idea to avoid putting more than 500 files into the root of ANY HDD. SOME files MUST be stored in the root, because that is where Windows expects to see them, but don't add any of YOUR files, the ones you create or download, into the root of the drive.
8. This numerical limit also applies to USB flash drives and other storage devices. You avoid this problem the same way, by creating folders in the root of the drive and storing all files inside a folder.
Good luck with this; let us know if you have any questions.
Apr 26, 2011 | Western Digital My Book Essential 1TB...
My external HDD is no longer recognised by my PC. The usb port I tried works with other devices so that's not the reason. The curious thing is that when I connect the HDD to my TV I can view & play...
Plug it in, then on your desktop right click the My Computer icon, then click on Manage. From the window that opens click on Disk Management. In the right hand pane, you may then see your drive displayed. Right click in the lower right pane on your device and click on Explore. If it open the drive to show the files, you should be able to come out of all the windows and then access the drive normally.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Western Digital My Book Essential 1TB...
It's been working fine. However, now when I click on the "external HDD" icon, I get all my folders -- but when I click to open them, they're either empty or it just hangs, won't open up after hours --...
You may have a corrupted external hard drive. Often, corrupted means your files are still there, but the directory on the drive is mesed up, and the files cannot be found. If you are on a Windows PC, right click on the drive in File Explorer. Then choose Properties / Tools / Error Checking / Check. This should find and fix basic problems on the drive. Before that though, just try the external drive connected to another USB port, and if you have one, using another connecting cable, just to rule out problems with these items.
Nov 13, 2017 | SimpleTech 320GB SimpleDrive External by...
Computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Apr 20, 2010 | Western Digital My Book Essential Edition...
Hi I purchase an Iomega External Hard Drive 500 gb and I am using it in PC format however, when I connect the hard drive it gives me an error when I try to format it. I tried Windows vista home Basic,...
ur harddrive couldnot be formatted probably due to the infection of virus.
try this use window xp and connect ur hard drive open task manager by Pressing CTRL + ALT + DELETE
click on the process tab a list of all the processes going on will come,there u will find a process named explorer.exe
right click on it and select end process tree click yes
after that click on applications tab and click new task
enter explorer.exe on textbox and click ok.
now dont open ur external hardrive ,open mycomputer then quickly format ur hard drive.
Mar 31, 2010 | Iomega 33089 250 GB Hard Drive
External hard disc not accessible
hi there...if this thing happen to your external HDD you have virus in your external hdd. so the solution is connectthis external to your pc/notebook then if already detect by system don't try to explore it or else just click cancel if system ask at popup windows.
in windows explore at your exernal id double right clik and choose format with default allow size...wait for a minute ( depend how big the size of your external). and don't forget to close all program first (music etc) when you formatted.
about geeting your external data back you can use program Office Recovery.install it at your pc and you can backup your data using : office recovery--media heal for hard disk....
good luck
Feb 02, 2009 | Computers & Internet
Wd my book
ok? hmm can you see the drive in "my computer?''
goto: start >control panel > admin.tools> device managment and look under the driver managment in the USB section there should be "usb external mybook HDD" or similar. if there is righ click it and in properties check that it is running fine and no conflicts...
if it is not there ir no problems appear. goto the disk managment further down on the left side and ur internal HDD and the book shold appear right click the book and select explore! if it does not let u that is because it was not assigned a drive letter or path tis is a driver error and a service or driver upgrade will correct.
now rightclick and select change drive letter/assign drive letter. then click add... then give it a letter.
try explore again it may say error. then try again it WILL let u in. but may jumb back to the "my computer page" just click the back button and it will appear.
good luck lamby.
Jan 29, 2008 | Western Digital My Book Essential Edition...
Free Agent
hard drives, ok your router connects via a usb yes? and by the sounds of things you unplugged the HDD and pluged in the router. ok, there could be a driver error, as your HDD and router may be refering to the same port as each other. try, restarting the computer in SAFE MODE and plugging the HDD back in, before windows starts up! now click... start > control panel > admin. settings > computer managment and click DISK MANAGMENT. descriptions of your HDD(s) internal and external and cd/dvd/br optical devices should be listed. now if the HDD (free agent) is their, right click it and click, explore. if it does nothing or comes out with and error message look to see if it had a letter assigned to it... eg: (c:) (d:) (e:) and so on. if it doesnt, then right click again and change drive letter and paths, then click add and select a letter. once this is done the HDD will have that letter assagned to it. now right click and select explore again it may error again but give it a sec and then try again, the Device WILL open (as long as the HDD hardware is ok) but if the driver is dead, which i suspect is the case, then a window (your HDD) will come up but suddenly dissapear! to get back to it just click the back button.. if your is acting the way i have described then your driver is corrupted by another or some software incedent. so go back into computer managment and click device manager and search around for the mass storage driver either in the driver area or the USB area. ((me)only own WD and samsungs) now right click te driver and look through the tabs to see if their are any corruptions or errors. fix this by selecting a different 'instance' for the device. if all fails delete the EXTERNAL HDD driver and restart the computer. other than this the HDD may be the one to blame, but i seriously dout it! good luck .
Oct 07, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
529 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
