Question about Toshiba A205-S4577 Notebook
Ethernet NIC card not seen in Network adapter (code 31)
Hi! Had a lightning strike close to house last week. Was watching TV when it happened without a warning and heard a Pop at the cable modem and everything went off. Cut all power to everything at that point but when next time I tried to use my laptop could not see the LAN connection in Network connections via the Marvel yukon miniport fast ethernet nic(?). Doesn't show up when plugging the cable from the modem to the laptop. Loaded the drivers again from the disc and get yellow exclaimation point (code 31) in the network adapter folder in Device Manager. I'm assuming I have a hardware problem, but haven't taken the laptop apart yet hoping another fix is possible. Thanks!
  • Joseph Fuller Jun 21, 2008
    Well, I have loaded the device drivers from the support disc, deleting and reinstalling them to try and bring it back up at least 3 times. The laptop is only 5 months old and I'm using Windows Vista system and not too happy with it at the moment. But, I would really appreciate any help you can provide. Thanks!
    OK, Thanks!
  • 85 Answers
Code 31 means that the device drivers are incorrectly installed.
In order to solve the issue fully, can you please tell me what Operating System you are using.
Posted on Jun 21, 2008
  • Simon Vann
    Simon Vann Jun 21, 2008
    From what you and from previous experiances, Im afraid to say that the NIC is probably fried. If possible try to get an engineer to check it out.
Will any Wireless Adapters work without the PC's NIC?
Yes even without any NIC card installed on your computer , the wireless adapter will definitely work since its a different device that work for wireless connection and has nothing to do with your NIC card configuration.
May 15, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Getting a no network adapter detected message after a nearby lightning strike. No Network folder listed under device manage either. Windows ex sp2
this network cards are the most commun problme on computer if the card is not detected on device manager remplace it
they cost about 10 to 15 dlls
May 04, 2010 | Dell Ethernet Card Network Adapter
Just reinstalled xp on a dell dimension desktop 8250 and the ethernet NIC Card just does not show up in the network settings. Everytime I look up the card in Device Manager it has a question mark. I did...
if u have another way to contact dells website with eather a flash usb or a cd get the drivers from dell for you nic then go start/control/system/device manager and update your drivers for that nic
Dec 05, 2009 | Dell Ethernet Card Network Adapter
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Connection Cable Unplugged Realtek RTL8139/810x
I got the same NIC (Network Interface Card) a few weeks ago, and my connection has been dropping out as well. I've tried different versions of drivers, but without success. I was playing around with the NIC's settings, and this is how I fixed the problem.
Right click on "My Computer"
select "Properties" from the list
select the tab named "Hardware"
click on "Device Manager"
expand the tree item named "Network Adapters"
right click on the Realtek RTL8139 and select "Properties" from the list
go to the "Advanced" tab
Select "Link Speed & Duplex Mode"
On the drop-down menu to the right, select "10M Full mode"
Click "Ok"
close out of Device Manager and My Computer properties.
The problem should be solved. The only disadvantage to this is that speeds on a local network will be slow on this computer, or if you're lucky enough to have a +10 meg line straight to your house.
Hope I helped,
Daniel
Apr 09, 2009 | Televison & Video
Nic card issues?
Do you have any 2.4MHz cordless phones in the house or is the computer near a microwave? those two items can cause interference. You can go to Dell.com, go to support then download drivers/software, enter in your service tag is best if you know it? find the network card driver and download it. You can find out which NIC card you have by going to my computer, system, then device manager and right click on the NIC, then properties, it will tell you what card you have.
Apr 08, 2009 | Dell Ethernet Card Network Adapter
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Toshiba A205-S4577 Notebook Logo
198 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
