One of the bulbs blew on my hood and it cut out. Have now replaced the bulb, reset it etc, but neither the lights or the fan will work.
Any ideas?
Comment by Calvera, posted on Jun 19, 2008
The fuse on the main fuse box is fine, which is why i thought it must be something internal to do with the cooker hood, unless there is a secondary fuse somewhere
I have a stoves chimney hood, we had some water come through and resolves this. A week later both bulbs blew and there was a spark!. The fan still worked. The next day, the fan stopped working. I bought new bulbs and they don't work and the fan still does not work.
I can't find the fuse? Any suggestions?
check the printed circuit board behind the switches - maybe when bulb blew it took out some of the track. usually repairable by soldering in a link over the damaged track. have you checked the fuse as well?
Rating Locked! (?) Calvera has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cooker Hood problem:
