Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Me too. And apparently the philips by Magnavox I got can not find the appropriate codes.
Posted on Sep 15, 2008
Can not assemble epson lamp in compartment
On the front right where it says LIVINGSTATION, that panel lifts out. Inside you will see two screws, loosen them, (they will not come out because of a retainer) gently pull the box out. Once it is out, there is a wire retainer that has to be removed. Once that is removed, then loosen the nuts from the bulb. Then reassemble. Putting it back in, takes patience, do be in a hurry when putting it back in. It will only go in one way, make sure the bulb is facing the inside when sliding it back in. Hope this helps you..I haven't yet replaced the whole unit from epson ($300) only the bulb, which didn't need it after all. If you have any questions e mail me..
Nov 16, 2012 | Epson Livingstation LS57P2 57" Rear...
Temperature Error Epson LCD
It probably needs cleaning. They build up dust after a while...
Jun 06, 2009 | Epson Livingstation LS57P2 57" Rear...
Can't turn on television two red lights on television
Make sure that all of the access doors are properly closed. There are interlocks there that will prevent the set from working if the door is open. Also, check to be sure that the fans turn freely and are clear of debris.
Please keep us updated on progress.
May 30, 2009 | Epson Livingstation LS57P2 57" Rear...
Purple spots on the bottom and middle of my EPSON livingstation tv.
Search for this problem by using the term "pink bloches" I already explained the solution.
Oct 28, 2008 | Epson Livingstation LS57P2 57" Rear...
Red blotches on screen
Serce this questin using the term "pink bloches" I explained it there.
Oct 10, 2008 | Epson Livingstation LS57P2 57" Rear...
Need the codes for a lloytron jumbo remote
need the codes for a lloytron jumbo remote for my sony rear projection kf42sx2000 and sky plus many thanks Steve
Apr 07, 2008 | Epson Livingstation LS57P2 57" Rear...
Life of a bulb
I too have an early P1 series Livingstation with a bulb that MAY be going out. I've been searching online and found several suppliers with prices ranging from $249 to $367. the Epson store seems to be the cheapest and probably most reliable supplier at $249 including shipping!
The stated life of the bulb is 10,000 hours ... and I've had my LSP1 for perhaps 4 years. We use it kind of heavily - and I'd say we've used it roughly 30-40 hours a week... and over 4 years I'd say that equates to 200 weeks at 30-40 hours = 6000-8000 hours of use already. So, once I replace the current lamp - if the replacement works well... then I'll immediately buy a spare bulb. That will enable effective use for another 20,000 hours with the new replacement and spare. That hould last me about 9-11 more years for only $500 or so.... assuming I get 4.5-5.5 years of use per bulb.
Jan 05, 2008 | Epson Livingstation LS57P2 57" Rear...
LS47P1 Epson Living Station
Sounds like it might me a source or connection issue. However, you would know to check that - right? Just the other day i had a damaged cable cause an image problem. I replaced it and all is well again.
If not a source or cable issue - then this sounds like you'll need a service call from an Epson tech. I'd give them and - might I add - I'd apprecaite knowing how this turned out. I wonder how I might have to deal with problems down the road... IE get service and fix it or just throw out the Livingstation!?
Dec 16, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 TV Power Won't Come On
tryin unplugging t.v for an hour then plug it back in it worked for me i have the same t.v just the 47 inch
Jan 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
64 people viewed this question
Top Epson Televison & Video Experts
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
