Question about Samsung ML 2010 Laser Printer
Fain printing i was out of toner then i refilled the samsung ml 2010 laser toner cartridge myself simply using the opening of the toner chamber by the side of the cartridge. i used the toner that i refilled my old hp laser printer mnay times and it worked. the result with my 2010 is that it has a faint printing. i dont know what to do please help
I'm using remanufactured toner provided with my ML-2010 by Discount City when I purchased the printer and I'm having the same problem.
I have used non OEM toner in other laser printers also with disasterous consequnces so I think you'll have to 'bite the bullet' and purchase a new Samsung toner cartridge unless you can find out who manufactures the cartridge in which case you might be able to souece one directly avoiding the extorionate mark up.
Posted on Jul 03, 2008
SAMSUNG ML 2851ND TONER REFILLED BUT, NOT PRINT PROPER. 4-5 DARK VERTICLE LINES COME IN PRINTING.
you are using a mono laser printer
possible problem:
The surface (drum part) of the toner cartridge inside the machine has probably been scratched.
Remove the toner cartridge and install a new one.
Jul 17, 2011 | Samsung ML-2851ND Laser Printer
I refilled my toner ml 2010 when i print the right side of the page is very light hardley any ink
You need to clean the ink cartridge. Check for software on you computer under programs. You could also put some rubbing alcholol on a parer towel and lightly rub the print heads clean.
Jun 15, 2011 | Samsung ML 2010 Laser Printer
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
I am using samsung ml-2245 when refill the toner it is acccept the toner
Perhaps you'll need to replace its lockout chip. Toner cartridges have a page counter and that needs to be reset after the cartridge has been refilled. Printing won't commence when the lockout chip has not be replaced with a compatible reset chip.
Nov 14, 2009 | Samsung ML-2240 Laser Printer
Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 26, 2009 | Samsung ML 2010 Laser Printer
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
Sep 05, 2009 | Samsung ML 2010 Laser Printer
How do you add toner in Samsung ML2010 printer w orig cartridge?
all samsung cartage can be refill.we use on it non magnatic dust. whi is define in ur purchase box. there is cap in cartage. from we can putdust. if ur printer shown cartage empty u shold reset it by fuse/cheap .
Jun 11, 2009 | Samsung ML 2010 Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Samsung ml2010 has faint printing
There could be 2 problems. 1. The "Toner Save" option is turned on. You could disable this by clicking on the toner save button or disabling it in the printer drivers. 2. Trying shaking the Toner cartridge. (This sounds crude but believe me it has worked many times).
Dec 20, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
195 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
