My laptop will not run any programs.low virtual memory
  • 100 Answers
* upgrade ram
*restart ur laptop
Posted on Jun 19, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
The best solution is to add more memory and remove the unwanted programes from the start up
Jyo
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Virtual memory low
Go to my computer Properties -> Advanced Tab -> in Performace Click Settings-> Click Adjust for besr performance-> Apply->OK ... Try it...
Remove all temporary files...
Jul 08, 2013 | Sony VAIO Computers & Internet
I want to increase my virtual memory to add an educational program for my son but the system says needs 3mb to run program and virtual memory low help someone
How much memory does the laptop have? Click Start/Control Panel/System. Look for How much Ram you have on the system. Then we can check to see if it can be increased.
May 30, 2012 | Toshiba Satellite A105 Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Low virtual memory
Virtual memory means you're running out of memory, so it's using your hard drive storage as memory. This is slow. This is an indication you: Have too little memory and need to run fewer programs or install more memory; and also increase the size of your virtual memory, which will also make your disk space tighter. If you are really pinching the computer that badly, you may want to consider buying a new laptop altogether -- the prices have come down a -lot- just in the 2 1/2 years since you bought that. Anyway, to work around the immediate problem:
Your Gateway came with Windows XP Home Edition. Click Start: Control Panels. See if you can find the Performance control panel, possibly by switching to "Classic view." In there, look for the memory tab. Find the virtual memory section. It may be set to "Let Windows decide." change it to at least 1000mb.
You can get a bigger hard drive (after buying an external case to move stuff over) and upgrade your memory to as much as 1.25gb; but you may find those purchases to not be sensible relative to the price of a new laptop. Memory is cheap and relatively easy; the hard drive is more difficult and will set you back at least $100 if you do it yourself.
Dec 05, 2008 | Gateway 7210GX Notebook
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Virtual memory low
naz2172, Buying memory is always a good idea.
Buy as much as your laptop can handle, to eliminate your problem.
Feb 19, 2008 | Computers & Internet
Internet explorer not opening (memory problem?)
if your system is running low on memory, the pc will not be able to run the programmes as normal as it will use virtual memory which enables the system to open up programmes that you use regularly without searching for the start up files reciding on the hard drive, but if your system is low you will get these screen messages. Either upgrade the system with more memory or check what programmes you have running on start up using your memory, press start>run, then type msconfig and look at the start up tab and untick any unnecassary programmes that start up,then click apply for a restart, as this will release some of your memory. On the other hand there may well be a problem with internet explorer itself also, so you can download the latest IE7 from microsoft if you wish and see if this solves the runtime issue
Aug 24, 2007 | Toshiba Satellite M55-S331 Notebook
Computers & Internet Logo
David Payne
David Payne
