Question about i-mate Cell Phones
Probably something simple but its got me stuffed.When my alarm goes I no longer have the option to dismiss it and when I turn the phone on the alarm goes off and again I can not turn it off. The phone is an i-mate jamin
    Genius:
  • 2,035 Answers
This is the problem with corrupt software of the phone, please reinstall the phone software from the local mobile service center or if within warranty get it done by the phone company:
Good luck
Posted on Jun 19, 2008
I have a problem with the alarm function of my LG Optimus Dynamic. I use it as an alarm clock and also to alert me several times a day to take medication. The problem is that about 40% of the time, the...
I hope the phone you're referring is an Android phone. Not only LG, but in most cases those android phones require a master reset/a refreshment from time to time. Do a backup and master reset the phone. That will definitely solve the problem you're facing.
Find for any updates for your phone if there are any and keep the phone OS up to date.
And as for another suggestion, keep some free space for apps to work by moving your photos and videos and other documents into your memory card. That'll speed up the things a little bit more. But make sure you leave some free space in the memory card too and use a good quality memory card.
Jun 08, 2017 | LG Cell Phones
I have a Samsung Galaxy Ace. When the alarm went off, I pressed the home menu key as I picked the phone up, and was then unable to get to the screen where I could turn the alarm off. After a couple of...
GALAXY ACE-HOW TO TURN ALARM OFF - Hi, you've probably figured it out by now but just for any other new users who are still struggling, here is the answer: Galaxy Ace : When your alarm is going off and you lose the screen option to either snooze or dismiss, simply look in the top left of the phone and you will see the little alarm icon with an exclamation mark on it, on the top bar where the signal strength indicator and the battery icon is. You can scroll your finger down over this top bar and move it down over the top of your current screen, and when the alarm is ringing, the option to either snooze or dismiss the alarm also appears on this pull down screen. Peace at last!! Hope this helps someone.....
May 05, 2011 | Cell Phones
Alarms
press ok..tools..alarm..select the alarm u setup..here is where u can turn on /off by toggle with the left / right softkey (dismiss)...alarm is off
May 29, 2010 | Sanyo Katana LX Cell Phone
How do I turn off the alarm?
Pageturn off alarm
When the display shows an alarm:
To turn off the alarm, press Dismiss or Red/End button.
To set an eight-minute delay, press Snooze.
Here is the link for your manual: http://www.motorola.com/staticfiles/Support/Mobile%20Phones/Motorola%20Tundra%20VA76r/US-EN/_Documents/Static%20Files/VA76r_UG_att_9519A36A.pdf
Oct 22, 2009 | Motorola Mobility Tundra VA76r Cell Phone
When i set my alarm it goes off ok but dismiss (o2 orbit)
This is a known problem in other O2 PPCs too.
You can try setting alarm from O2 media Plus.
Even my brother does this for now.
Please Rate...
Sep 05, 2009 | O2 Xda Orbit Smartphone
When my alarm goes off my phone does not prompt me to dismiss or snooze. It use to but it no longer does. I either get so frustrated and want to throw the phone or I just don't hear it and am late for...
Disable the old alarm and create a new alarm and see if you get the same result. For example if Alarm1 is the one not working, make an Alarm3 with the same setup. I had a similar problem with my Samsung phone. Alarm1 stopped allowing me the ability to snooze. I created a new alarm in a new slot and it is working fine.
Apr 25, 2009 | HTC Touch Diamond Smartphone
Razr V3 Alarm Will Not Shut Off
My Razr V3m also has this issue. One way to shut the alarm off is (1) make a call to your cell from another phone. (2) Disconnect the call from the other phone without picking up (3) You should see two events on your cell - one for missed call and the other for alarm. (4) Delete the alarm event first and then the missed call.
Drawback for this solution is you need access to another phone...everytime :-(
Sometimes, I am able to shut the alarm successfully without any problem
Aug 22, 2008 | Motorola Mobility RAZR V3
Alarms and reminders
the one issue where when you powercylce and the allarms come back on is an issue with all windows mobile devices called a phantom alarm....it sounds like a sw malfunction....do a master reset, by going through start>settings>clear storage....back up your info fist by using the PC or the memory card....this will remove all of you info and your settings.......if you are using an outdated sw you will have to reinstall and that should fix the problem...
Dec 11, 2007 | T-Mobile MDA
T-mobile dash multiple alarms
The solution is a follows; If you have any legit alarms already set, disable them before proceeding
1) As soon as the unwanted alarm goes off , look at what time your phone says it is and make a note of it. (if you know EXACTLY what time it goes off at, then go to the next step)
2) Goto Start -> Clock & Alarm -> Alarm
3) Set the alarm time for the exact time from step #1. Set alarm to On.
4) Click Done, done, and done
5) Goto Start -> Clock & Alarm -> Alarm
6) Change the alarm to Off.
7) Click Done, done, and done
That's it, the alarm should now be disabled for this unwanted alarm, if you have multiple unwanted alarms, repeat this procedure for each.
Dec 11, 2007 | T-Mobile Dash Smartphone
Cell Phones Logo
Top i-mate Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
