Question about LG Washing Machines
Lg washer model no wd 8013c door wont open tried everything and the child lock is disengaged
  • Anonymous Jan 27, 2009
    yep - keeps happening...sometimes redo the rinse and it releases, but full of clothes and dead stuck now!
How to get the door open:
Thread a shoelace between the door and the front of the machine from the top, over the latch on the middle right and to the bottom. Pull both ends of the shoelace towards the hinge on the left and this will manually pull open the latch with NO DAMAGE. Once open you can access the screws to remove the mechanism and simply buy a replacement.
LG, bloody hopeless support and no simple way to rectify this problem in the manual when it's so easy once you know.
Posted on Jan 21, 2010
Lg Washing machine. WD11020D will not open.
door lock sounds like its broken, you will need to remove the two screws on the back of washer top and remove the top. (power off) now as you look at washer from the front you will see a round object with a pipe. remove the pipe and see if the door opens. this is just to check to see if its this part stopping the door to be open, you are going to need to use a flat blade to push the pin in the lock you should see the pin as this stops the door from being open. the part looks like this https://www.ebay.com/i/253266384384?rt=nc if the door is slammed or banged, it can damage the lock, easy to replace when the you can open the door. wiring plug only fits one way.
Dec 06, 2017 | LG WD-1280FHD Front Load Washer
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
My washer had a CL error and the door will not open. I can't even turn it on or press the door lock. Nothing is happening
Child lock has been activated in your washer.
Please press Temp and Option button together in your washer for about 5 seconds after you turn on the washer.
If you do not have these two buttons check whether you have any button with a child's face as symbol , press and hold that for 5 seconds.
Nov 10, 2010 | LG WD-3243RHD Front Load Washer / Dryer
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Aug 23, 2010 | LG Washing Machines
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
Lg wd-8013c washer door latch broken. Is there an emergency release?
Run a shoelace between the door and the face of the washing machine, starting at the top, over the latch on the middle of the right hand side and down to the bottom.
Pull both ends of the shoelace towards the hinge on the left.
This pulls open the latch with NO DAMAGE and allows access to the screws that remove the latch mechanism. Easily ordered and installed with two screws and a plug to reattach.
LG give no support or reference to this easy procedure in their manual. SHAME!
Sep 14, 2009 | LG Washing Machines
Cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Apr 25, 2009 | LG Washing Machines
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
302 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
