Question about Hyundai ImageQuest L50A 15.1" Flat Panel LCD Monitor
How to open the casing of my LCD Monitor Model HP w 1907v
I have a problem of opening the casing of my LCD Monitor, I want to open it so that I can visually check inside.
I just bought that monitor from Saudi Arabia and I send it through a cargo company 1 month ago. I did not check the monitor yet after today because I went to our province for 1 month, when I tried to connect the said monitor It only open a few seconds and then there is no more light on the screen but it has a power indicator which you can saw on the switch light indicator.
If you can also pin point on the problem of my LCD Monitor I really appreciate it and it would be a great help on my side. I an an Audio & Video Technician before, thats why I am reluctant to open first the said LCD Monitor, expecting that maybe there are some loss connections only because of the handling of the cargo company.
Thank you very much for your help in advance and more power.
Manuel G. Del Rosario Jr.
Posted on Oct 23, 2008
HP vs19e monitor now dead. It flashed weakly, then quit. The push-button power switch will not turn on the indicator light. I have tried a different power cord, but still nothing. How does one open the...
There are four tabs at the bottom edge of the case tha needed to be release to open up the case.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
No power when u plug in an turn on HP vs15 15 in. Flat Panel LCD Monitor.can u tell me how to open it up so i can check the switch
You need thin flat blade screw driver to crack open the case, it is almost the same as VS19, more likely to havebad caps with bulging tops, see pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Mar 10, 2010 | HP vs15 15"LCD Flat Panel Monitor
Lcd monitor
It depends to the make and model of the laptop. In some cases you need first to open up the panel underneath to get to the screws that locks the LCD hinge before you can take out the monitor and take it apart.
Dec 07, 2009 | HP Computers & Internet
How to open acer lcd monitor model no AL1706A
gulabgoud, Most monitors come apart the same way, or almost!!! May I suggest that you visit YOUTUBE to search and view some video clips of VALID (good) "lcd monitor disassembly" and / or "lcd monitor repair" ??? Have you ever heard the expression "a picture (in your case video clip) is worth a thousand words" Good luck guy, your on your own!!! If this helps you out, please rate this response on fixya. But don't come back here CRYING or complaining IF YOU SCREW UP YOUR MONITOR !!! Bye for now.. 12fix louie
Nov 13, 2009 | Acer Computers & Internet
Want to know the site for downloading drivers
By the LCD monitor u mean the Video driver? There's a programme called 'Everest' here's the link: http://www.softpedia.com/progDownload/Everest-Home-Edition-Download-16369.html
Download & Run it n find your motherboard make and model.That will make much easier to search for the driver then.If that doesn't solve the prob. then lemme know.
Jun 01, 2009 | Computers & Internet
How can i open the body or case to repair of hp vp15 lcd monitor
well being as how i just did this five minutes ago I can help:) The back of the monitor has a thin panel like a sideways 8 or a bean shape...this pops off then you have to take out the screws holding on the base once you get that off you can lay the monitor flat <carefully> and pop the outer black frame off <every so often along the seam you will see little gaps stick a thin flathead in if it's to tight for you carefully not to scratch or break it is plastic!> then you will see the metal case and find the screws on the sides and your there! Good luck!
May 18, 2009 | HP f2105 21" LCD Monitor
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
May 17, 2009 | HP f2105 21" LCD Monitor
Need to open the case on an ACER 24" LCD Monitor
You are advised to take it in to an authorised technician for repair. Never open the case unless you are qualified and certified.
Jan 02, 2009 | Computers & Internet
Hyundai ImageQuest L50A 15.1" Flat Panel LCD Monitor Logo
447 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
