Question about Sony Handycam CCD-TRV37 Camcorder
Sony DCR-VX1000E batteries
Purchased unit many years ago. Great Digital Camera - work fine. Supplied battery started getting old. Replaced with two NP-F730 Li-ion batteries . 7.2V, 3700mAh.
They never came up to scratch! Fully charged and inserted the camera indicator only showed 3/4 charged. I get about 20 mins only on playback.
I have a constant current lab power unit whith which I could fully charge for 10 hours at 370mA. Should I do so?
The charger is erratic? I cannot run the unit from main (via the charger- no green VTR/Camera lamp.), nor can I charge the in camera unit and the one in the charger at the same time.
Is it the charger, supplied connecting cable/connectors or the batteries?
Can you help please?
regards George Frost
georgefrost@telefonica.net
    Sergeant:
    Champion:
  • 319 Answers
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Posted on Aug 01, 2008
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Dead battery
Charge the battery using the supplied USB cable. The salesperson meant that the battery would last for years before it will no longer take a charge and need to be replaced.
Apr 06, 2009 | Sony NWZ-E438F Digital Media Player
Sony vx2100 internal battery no longer holds charge
battery is inside the handle... open the three top screws of the handle cover and remove the cover. you can view the batteries.. replace both of them with same type.
Mar 27, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
HOW DO I SET DATE & TIME-ALSO GO FROM SP TO SLP
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Sony Model DCR-TRV350 Tape stuck in camera.
take out the battery, put it back, turn it on and you take the tape out of the camera. hope this helped you. have a great day.
Mar 03, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Batteries won't charge?
I would return it and get a new one, and if that doesnt work then buy a different one because these ****. I am stuck with mine, but I wouldnt suggest it to anyone...
Jan 10, 2008 | Sony Handycam DCR-TRV130 Digital Camcorder
Battery/Camera problem
Return the battery to Radioshack and try another brand of replacement battery. It is possible that the Radioshack battery is in stock for a long period of time. batterries have limited shelf life and it gets worse if they are left discharged for a long period of time.
May 28, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another...
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Apr 11, 2006 | Sony Handycam DCR-PC330E Mini DV Digital...
Sony Handycam CCD-TRV37 Camcorder Logo
166 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
