Question about Sharp Audio Players & Recorders
Would like a turntable belt for a sharp vz3000
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi markieboy15
    hese decks are cool. Upright turntables were a huge novelty in the 80's. The original belt NBLTK0184AFZZ for your machine is no longer available. If you can measure the circumference of the of the drive surface on the platter itself, I can suggest where to get one.
    Where abouts in the world are you so that I can send you to a local supplier.
    regards
    robotek
  • 1,512 Answers
Hey again, markieboy15
Still waiting to hear back from you about your locality
regards
rodotek
Posted on Jun 22, 2008
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Turntable not working
Remove the bottom cover to the oven and check to see if a rubber belt exists, if so it may have stretched and may be slipping. Replace the belt if one exists.
Dec 22, 2013 | Sharp R-1610 Microwave Oven
Turntable does not turn
some models have a drive belt that turns the turntable..it may have broke....also, the motor that turns the turntable may be defective...A word of caution...there are potentially lethal voltages inside the microwave, please be careful if performing repairs yourself...there is a "can type" capacitor that WILL hold a charge for several weeks and can kill you if you touch it, so be CAREFUL
Dec 16, 2010 | Sharp Microwave Ovens
I need a replacement turntabl drive belt for a SHARP SG-450E Hi Fi system, any idea where i can get one from please
Generic replacement belts are available from a number of suppliers, but you need to know the dimensions of the original. My cross-reference guides for a couple of companies don't list your Sharp model so I can't give you a specific part number. You might try taking the old belt to a service shop. If they have a belt gauge they might be able to order a suitable PRB brand or equivalent replacement for you.
Doing a search for your model turned up this vendor (in Australia!) who claims to have the belt in stock. They offer international shipping, so maybe this would work for you.
Good luck, and thanks for using Fixya!
Feb 03, 2010 | Audio Players & Recorders
I have a JVC L-A11 turntable. I cannot get the
I just had my L-A11 in to 'the needle doctor' (Jerry Raskin's shop in dinkytown, Minneapolis) We had the same problem with the platter.
After pulling (hard) to no effect on the platter - using the holes near the spindle and pushing simultaneously on the spindle. The tech next got out a small hammer, and while pulling on those same holes in the platter, he gave it a sharp 'whack' on the spindle with the hammer, and it came right off (the platter). I would have been too feint of heart to do it, but it worked great.
Oct 25, 2009 | JVC AL A158BK Turntable
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Belt on turntable needs replacing
should have a retainer clip of some sort right in the center of the platter. Should look something like this, you will need to take it off first.
Jan 29, 2009 | Sharp Audio Players & Recorders
The turntable on our microwave has stopped turning, R-510HK. Where can I take this unit to be repaired. Or is it cheaper to buy a new one?
Problem: Fans or turntables that do not work.
Possible causes:
1. Gummed up lubrication or bad motor bearing(s).
2. Loose or broken belt.
3. Bad motor.
4. Bad thermostat.
5. Bad connections
Oct 19, 2008 | Sharp Microwave Ovens
I have a Sharp VZ 2500. The drive belt lies in pieces at the bottom of the player, so I can assume it needs replacing. I've bought the belt, but have no idea where it goes. Can you help?
you have to remove the front cover first. then detach the two wire connectors attached to the turntable circutry. Also detach the pushbutton pannel. remove the two screws that fix the top plastic cover inside the turtable housing. then the two big screws that fix the turntable to the main body will be visible. remove them and you can detach the turtable unit out. then remove the circuit board behind the turntable. you can then put the belt between the big disc and the motor pulley on the corner. Good luck
Aug 03, 2008 | Sharp Audio Players & Recorders
62 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
