Question about Hotpoint TDC32 Electric Dryer
Hotpoint condenser dryer ctd00
The drum is turning with no clothes in.When clothes are put in drum turns very slowly then stops.
How do u put a belt back on a hotpoint condenser dryer
Posted on Mar 17, 2010
  • 625 Answers
Change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Posted on Jun 19, 2008
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Why is my hotpoint ctd00 condenser dryer leaking water from underneath and turns the electricity off''
you are not on your own we have the same problem we are going to convert back to the old fashion tumble dryer
Dec 23, 2009 | Hotpoint Dryers
Hotpoint Clothes Dryer (ctd00) is tearing clothes.
Hi, It sounds likethe front tub bearing (Glides) might be wore down. To raise the top....... there are two screws located where the door closes to the front panel that hols the top down. Remove those screws and the top should raisse up. Look down toward the front of the drum and see if the glides or felt are ok.
Hope this helps
Vic
May 07, 2009 | Hotpoint Dryers
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Hotpoint TDC32 Electric Dryer Logo
752 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
