Question about Mitsubishi WD-52525 52" Rear Projection HDTV
V-chip on TV
Lost the password
  • 31 Answers
(turn ther set on) you will need to hit QV and the number 9 (at the same time) got to where it ask you for the password and hit QV and the number 9 again (at the same time) and it will reset the password.
Posted on Aug 14, 2008
How do i reset parental control when we have forgotten password
You should be able to find it in your TV's manual.
If you lost your manual, here are some possible options:
  • Try pressing the recall button 5 times quickly within 30 seconds.
  • Hold the Volume button down and push the Number 1. Then go to the V-chip button and enter there your new password.
  • MENU button, press SET +/- button to select V-CHIP SET, press ENTER button. Enter password using channel selection. Enter same password confirmation, ENTER Press SET +/- button to select V-CHIP
  • First press menu button then select set or v-chip set obtain then press the enter button then enter the password in four digits. v-chip password will set then we using the direct channe
Your TV model would help a lot, but I hope you find your manual or one of these work.
Mar 02, 2011 | Televison & Video
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Jan 21, 2010 | Durabrand DU1301 TV
Lost password
Turn the volume down to 0 then change to a blocked channel. (where it asks for v-chip password) Next, on the TV, not from the remote, hold the volume down button, and hold the '0' key on the remote for between 2-10 seconds... the screen should unlock and you should have no V-Chip restrictions.
Jan 25, 2009 | Orion1934 19" TV
Piva ptv1502 screen keeps cutting off while playing can you fix problem?
If it's a V-Chip, Parental Control issue, here's the solution. Make sure RF coaxial cable is connected to TV. Press "V-Chip Menu" on the remote. On Password, press "Enter" on the remote. In Password, enter 666666, then press "Enter". Scroll down to "Modify-PW" by using CH+ or CH- key, then press "Enter". Enter 000000, then press "Enter". Select" V-Chip Menu" to exit V-Chip. Select V-Chip Menu again. On "Password", press "Enter" key on remote control. Enter 000000 in "Password", then press "Enter". Scroll down to "V-Chip", press "Enter". TV should display a list of all TV ratings. Use CH+ or CH-, scroll to TV-Y. Then press "Enter" key on remote. Be sure that all ratings are set to "On". Repeat the steps above and set all ratings to "On". Then select "Exit", press "Enter". Press V-Chip Menu" to close on-screen menu.
Oct 30, 2008 | Televison & Video
V-chip or parental control
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Orion 1929
For your Sony remote, the Orion codes are 082 and 087.....
RCA codes are 030, 035, 191
Or use search mode ( complicated )
Or www.mrremotecontrol.com............
Please rate this solution....................
Nov 14, 2007 | Orion1934 19" TV
Forgotten v chip password
hi i have a vivid 106 cm plasma sold by aldis in australia i am now in portugal and canot change the country in the tv to get Digital tv
Aug 15, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
