Question about Miele Dryers
The drum is not spinning on a miele dryer, model T5206, the appliance is generating heat, the brushes are intact and also the belt on the centre of the drum is intact.
  • simon green Jun 19, 2008
    the belt on the dryer is around the centre of the drum external and visable if you remove the top lid is this correct? also were is the tensioning spring located? i have no electrical or mechanical drawings for this appliance.
  • 625 Answers
The tensioning device [ spring] is weak or the belt is stretched beyond its usable length. if a new belt has been installed, the tech didn't put the belt on the correct side of the tensioning device. it is possible to install it wrong.
Posted on Jun 19, 2008
  • THOMAS MIERZWA
    THOMAS MIERZWA Jun 19, 2008
    the motor and tensioning device is bolted to the bottom of the cabinet. since you already know how to remove the top, look to the front cabinet panel and see if there are two bolts to remove to release the front panel. once you've done this, then you can see if the belt is getting chewed up by the motor pulley. on a whirlpool there are two bolts that come out and the front panel is lifted off two hooks. mind you there may be wiring associated with the front panel also.
Dryer powers on but drum does not spin and no heat. Drum is free by hand and door switch is functional - light goes on when door opens.
If you can hear the motor running when you turn the dryer on but the drum does not turn, it may be that the belt has broken or the idler has come loose. You don't mention the make and model of dryer but most are driven by a long belt that goes from the motor at the bottom of the dryer over the drum. It is held tight by an idler pulley. Google "drum will not turn" along with your make and model so find out how to gain access to the underside of the dryer to make sure the belt is intact.
Aug 12, 2015 | Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Dryer drum won't spin/tumble clothes
Chances are it's a broken belt. If you hear the sound of the motor running and your dryer is heating, there's nothing else but the belt.
Changing the belt yourself is pretty easy if you can use a screwdriver and have a little mechanical ability. The new belt is around $20, and you'll save big if you don't call a service person to do it for you. A good site with a step-by-step illustrated procedure for changing the belt is here. They also sell parts, or you can find the belt locally at any appliance parts store.
May 04, 2009 | Dryers
Miele T5206 drier repair manual
meile t5206 not heating up,everything else working ok. I have ensured all filters and vent pipes clear
May 16, 2008 | Dryers
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Dryers Logo
269 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
