Question about Philips DVP5140 DVD Player
DVP5140 only reads DVDs
Hi
My Phillips DVP5140 can no longer read music or picture CDs. But DVDs continue to function correctly(??). It tries 'loading' for a while, then says 'no disc'.
Any ideas?
Thanks in advance
Charam
  • 2 more comments
  • anne4prez Jan 04, 2009
    My Phillips DVP5140 does not read most CDs & DVDs. It either does not load or plays, then freezes in mid play mode. Is a Disc Cleaner able to solve this problem?
  • aphelion777 Feb 28, 2009
    I have the same problem basically, excepy mine will not read dvds. It goes from loading to no disc. How does one adjust a lens?
  • zishant Mar 01, 2009
    have same problem but both dont work, whenever I put in dvd it says 'NO DISC' same for cd. Makes noises and loads for awhile then displays no disc message
  • Dekaheptron Mar 02, 2009
    Hi, my Philips DivX Ultra DVD Player started a few weeks ago to read DivX Movies harder and harder, until couldn't load at all, saying "no disk"; then after couple of days started to read again sometime, but now after 3+ years of usage can't even display the red led light like is not even pluged any more in the power outlest (checked, it's plugged).
    Could you please offer me a solution, because it did a great job for 3+ years and me and my daughter we really love it.
    Thanks,
    Dorin
    Sergeant:
    Champion:
  • 297 Answers
The DVD player have two lenses.;cd and dvd lense,the cd lense needs a little adjusment so can read again..
Posted on Jun 19, 2008
I have a philip 3962 it can not read DVD but it can read regular audio can you tell me what happend
hi,
i have got the same complaint some days ago. your players spindle motor is faulty.
its winding have some problem. spindle motor is that one on which the dvd spins. when u insert the dvd it is not rotating at the required rpm. thats why it is not reading. the problem will not be with video cds and audio cds . because it doesn't required a high rpm. replace the spindle motor. it will not cost a lot. its sure that ur problem will be solved.
if then also the problem remains,
your player's laser pick up unit have some problem with its DVD laser. there are two types of laser in dvd players. one for reading and playing audio cds, mp3 and video cds and the other for reading and playing dvds. in your player dvd laser have problem. don't think that these are two separate unit. the lasers are mounded in the same unit. if any of the laser get damaged you have to replace the whole unit.
if u need any more assistance feel free to contact me through fixya.
bellow is the image of laser pickup mechanism
Apr 01, 2011 | Philips DVP5140 DVD Player
It reads CDs, but DVDs: "Please insert a disk in drive.."
DVD SOHD-16P9S drive doesn't read any kind of CD or DVD
hi,there is no problem in drivers .
check the hardware parts
there are 2 possibilities in your case
1.the laser beam which reads the dvd or cds is malfunctioning
2.ensure that the cable & buses are properly connected
in case laser beam is damaged you got to get it repaired for proper functioning
all the best
Dec 19, 2007 | Lite On SOHD - 16P9S Internal DVD Drive
Hi i have a sharp hp22 i ham trying to play normal dvds on it ? is that possible
All Blu Ray players that I have dealt with are what is termed "backwards compatible" which means they play Blu Ray, standard DVDs,music CDs,MP3s,recorded CDs and DVDs, etc. yours should have no problem reading and playing back your "normal" DVDs. Good luck !
Dec 27, 2009 | Sharp BD-HP22U Player
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
The DVD/CD drive will play some CDs and not others When it does not play, the computer hangs and can only be restarted by switching off/on at the mains.
If your DVD/CD drive was not doing this before, know that it is getting spoiled, especially on it's lens. Or the CDs and DVDs which don't play might be burnt on a higher speed which is not supported by drive. Try to use CDs and DVDs burnt at the speed recommended by the drive's manual, usually a maximum of x24 for CDs and x16 for DVDs.
Nov 20, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
CH dvd300 plays music cds wont read dvds states continuously insert disc
The non-technical answer would be that the lens needs to be cleaned. This is the first step for this type of problem. There are many things that can get the disk drive lens dirty like smoke, incense, dust, moisture. Open the unit and open the DVD cover. You will see the lens that reads a DVD. Get a cotton swab (the ones for cleaning out ears) and some isopropyl alcohol (rubbing alcohol) and moisten the cotton swab with the alcohol (moisten not soak) and gently (I mean, do not push hard or scrub hard) rub it on the lens. Now with a dry cotton swab, do the same. Let it dry for a minute (longer if the swab had more alcohol and it might have dripped down) and close the unit. Now try to play DVDs and let us know if it worked. If this does not do the trick then it could be a firmware issue that can only be fixed if the company put a download on their support page.
May 29, 2008 | Cyberhome CH-DVD 300 DVD Player
CDROM drive does not read some CDs
best and most affordable solution - replace the cdrom drive.
Sep 23, 2007 | Toshiba Satellite P15-S479 Notebook
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Philips DVP5140 DVD Player Logo
215 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
