Question about Canon FAX-L350 Plain Paper Laser
Paper Jam I have paper jam in our fax machine L350
  • 682 Answers
1-fan the papers many times befor you put in the machine.
2-keep the paper inside its cover in dry place.
3-check for any foreign object droped in paper path(pins-a small pieces of torn paper).
4-check for good condition of paper detecting switches in paper path inside the machine.
Posted on Jun 22, 2008
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Flashing paper jam, no jammed paper
Check to see if there is dust on the senor inside the fax machine, blow with some air can help
Apr 22, 2009 | HP 1010 Plain Paper Inkjet Fax
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
I CANT SEND ANY FAX
by opening the fax compeletly and clean it very carefully and after that I close it.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Repreated Paper Jam
clean the rubber tires with alcohol, under the tire that picks up the paper there is another rubber pad/tire or cork pad clean as well it is slipping and grabbing more than one page. if it continues you will need to replace
Aug 18, 2008 | Canon FAX-L350 Plain Paper Laser
Paper jam
There is either a jam in there somewhere where you can't see it, or if it clears, the feed roller is not feeding the paper, in either case you probably need a tech.
Jan 07, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Dec 13, 2007 | Canon FAX-L350 Plain Paper Laser
Canon FAX-L350 Plain Paper Laser Logo
182 people viewed this question
old marine
old marine
