Question about Samsung SGH-D900 Cellular Phone
D900i samsung mobile
Am trying to stop international calls but password attempts excess keeps coming up can you help
  • 3 more comments
  • doug10 Jun 19, 2008
    iam trying to use call barring but when put in code 1111 password attempts excess comes up please help
    phone will not let me barr calls after using code 1111 password attempts excess appears
    no factory reset on phone
  • doug10 Jun 20, 2008
    still no solution yo problem
  • Anonymous Dec 19, 2008
    i need password to open the phone lock thank you my mobile no 097150278954
    regards,
    francis
    Master:
  • 638 Answers
U hve tried everything with u simcard inside ur phone.actually u will hve to remove ur sim 1st then:
switch the phone on without a sim card,
type in *2767*2878# WAIT for it to reset,
once it boots up itself, the phone code is now gone.
then try call barring with :1111 or 0000.it will solve ur problem definately.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 20, 2008
  • 87 Answers
You don't even have to turn it off for one hour, just turn it off. if it says that 1111 is not accepted, then try 1683.... this is the override code. if this doesn't work, then you need to send the phone in.
also, if password attempts exceeded, push end call+1+call at the same time this will reset the attempt counter... if none of these work, then there are some serious problems with the phone
please rate this solution
Posted on Jun 19, 2008
    Genius:
  • 1,665 Answers
    President:
  • 1,257 Answers
It seems to me that you are not entering correct code for baring .so use the manual which came with your mobile,,it is not necessary that it will be 12345 as in case with nokia ,its a samsung mobile,so use the manual on how to use call baring....
  • Deeps . Jun 19, 2008
    *2767*688# = Unlocking Code
    *#8999*8378# = All in one Code
    #*1300# = IMEI
    *7465625*638*Code# = Enables Network lock
    #7465625*638*Code# = Disables Network lock
    *7465625*746*Code# = Enables SIM lock
    #7465625*746*Code# = Disables SIM lock
    *7465625*28638# = Auto Network lock ON
    #7465625*28638# = Auto Network lock OFF
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    Samsung say the only way to reset this is to
    return the phone for a software reset. The default password for call
    barring on O2 is 0000.
    Sergeant:
    Champion:
  • 230 Answers
Call barring service might be stops your international calls ,you can get the password for this from your service provider
    Master:
  • 788 Answers
The call barring default password is dependant on your service provider. I would call there support line and request the default password. Or they may be able to assist you with overridding your current password. It may even be easier to bring your phone in to one of there outlets as the clerks may be able to do this right away.
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Hello sir let me see your problem
Under UK law,telephone cold-callers must:-
1. Give the identity of the company or business on whose behalf they are calling.
2. Make their business purpose clear.
You can stop calls which originate in the UK by registering with the Telephone Preference Service. Otherwise you can simply take the advice I gave you in your earlier thread, and just put the phone down. It works surprisingly well
or sir if you having password problem try this
http://www.macworld.com/article/58777/2007/07/aug07workingmac.html?t=111
  • Samsung Master
  • 13,433 Answers
You can setup a restriction to international calls by calling your service provider and asking for a international call block or similiar.
  • Ekse Jun 19, 2008
    if you can't find out the code you can do a full reset on the phone, note that this will delete everything from the phone
    *2767*3855#
  • 2,071 Answers
Go to setting ,then set it for factory default,so your will be reset and everything will go on normally .This is tested allready of that kind of problem..
  • 796 Answers
Why dont you try to put a personal lock code for your mobile so that no one else could access it
    Guru:
  • 1,894 Answers
The phone is in locked conditons for international calls
i mean the calls are being barred
  • 1 more comment
  • dewan nafees ahmed Jun 19, 2008
    the call barring has been activated in ur phone.
    by using call baring u can stop the incoming calls in national and international levels.
    this is locked by using a baring password.
    this pin is always default as 1234 or 12345
    else it can be got from ur service provider also
    if u try to attend a call it asks for the password.
    this attempt if done more than 5 times the phone gets locked.
    and that is the stage where u are now.
    for unlocking this u have got few options
    i shall list u them here.
    do a hard reset of the phone and then try to use it. (but while using it again make sure u type in the right pass).
    if not call the service provider and ask him to unlock it.
    if not go to a local tech(expert in mobiles) to unlock ur phone. he will do it by connecting ur phone to the system and use a software to unlock it.
    thank you
    dont forget to accept the solution
    good luck
    have a great day
    oh i have mis understood ur problem i think. sorry
    then go to r phone settings and then go to call settings
    u wil have a option for call baring
    now if 1111 is not accepted
    try 0000 or 1234
    if maximum attempts is exceeded switch off the phone for 1 hours then switch it ON.
    u can again type it with new code
I need ptcl phone lock code 0572520171
Lock Unlock PTCL Code For Mobile & International Calls If you would like to stop making Mobile & International calling from your PTCL do following steps
  1. First call PTCL help line 1236 and ask them to open lock facility(it will take 24 - 48 hrs).
  2. Once facility is available you can lock phone by dialing *33*1234*4# (replace 1234 with your desired password).
  3. To unlock phone dial #33*1234# (Replace 1234 with your password).
By doing this i lock my PTCL mobile & international dialing.
Nov 05, 2010 | Cell Phones
Puk code for samsung d900i
you will need to get ahold of your cell carrier they can give it to u
Oct 02, 2009 | Samsung SGH-D900 Cellular Phone
My samsung D900i is showing "limited service" for the pass five days now, I can't call and... (More) my samsung D900i is showing "limited service" for the pass five days now, I can't call and I can't...
that is because you dont have mobile signal at all or very poor in your location. try to get somewhere else to see if it improve. maybe you have to go long way.
you can see it somewhere on top corners of your display
[battery is one and signal is the other one]
Aug 07, 2009 | Samsung SGH-D900 Cellular Phone
I entered #*7337# to my D900i Samsung mobile
entered #*7337# to my samsung sgh D900i...then it said EEPROM RESET,I lost my sgh D900i imei and..
Jul 25, 2009 | Samsung SGH-D900 Cellular Phone
Blocked my simcard ,need puk code for a samsung d900, help?
you need to contact your mobile service provider to unblock your simcard (PUK)
Jun 03, 2008 | Samsung SGH-D900 Cellular Phone
Sending a picture message to my email address
contact your mobile service helpdesk and have them assist you
Feb 26, 2008 | Samsung SGH-D900 Cellular Phone
Lost SAMSUNG D900I mobile phone
On the Box that the phone came in there's an IMEI (International Mobile Equipment Identity)
number, with this number your service provider can block the phone from being used with yours, or any other SIM card.
Feb 22, 2008 | Samsung SGH-D900 Cellular Phone
Samsung D900I mobile
wen u connet ur cables go to files click on it u will find this in the top left corner wen u av dun tha click on connet it shud work
Jan 12, 2008 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
318 people viewed this question
Top Samsung Cell Phones Experts
kenneth njonjo
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
