Question about Apple iBook G4 Mac Notebook
Ibook g4 freez
I have ibook g4- when i put os cd to install a new system hd doesn't appear
- when i run disk utility to formate hd it apears but the screen freez . i trayed meany times & i had the same result.pls tell me what can i do ,is there any boatable program can fix this problem.
i look forward to here from u soon
thanks
sony
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Freezing is a HD problem. Do you hear clicking sometimes? Sometimes on boot up is there a foler with a questionmark in it? I would get your hard drive looked at, this is the reason disc utility fails. Your hard drive has a hiccup.
Posted on Jul 04, 2008
I have replaced my harddisk in ibook G4...how to install mac os
The problem appears to be that your ibook is only a G4 processor snow leopard needs an intel processor. The highest system you can instal on it is 10.5 i.e. leopard.
Jun 25, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Im getting a folder with a question mark
boot from an install or system CD, after selecting english the next page has a menu along the top, select utilities and then disk utility, if the HD is ok it will show up when the daisy or beach ball stops spinning, if it does not you will need a utility like disk warrior, if there then select repair disk, when this has run select repair permisssions, this is slow. when done go back to utilities (you may have to quit disk utility and open the utility folder again and select start up disk, your HD should show up, select it and restart. if this fails you have to try am archive and install.
Jan 11, 2011 | Apple iBook G4 Mac Notebook
My Apple g4 laptop was working a few hours ago, but then wouldn't start up with the password prompt and has a small icon with a question mark and appleface symbol. It has a DVD in it that I recently...
The disc will eject if you start with the clicker pressed (same with a mouse) the machine is OK but cannot find a viable OS boot from a Cd and in the top menu find the utilities folder, in there find disk utility and if the hd shows up select it and select repair disk, if that runs select repair permissions, then go back to utilities and find start up disc and select rour hd and restart
Dec 07, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
I picked up a Powerbook G4 12' Aluminum guesing 1.5 from a local college that was going to trash it, and when I press the power button the start up chime rings and turns straight to a blinking ?/Mac OS...
Get the gray OS discs specific for the PowerBook. Your iBook gray discs won't work. You can also install the OS by getting a black label retail version disc of whatever cat you like- Panther or Tiger. If the software installs, but you hear noises or get the spinning beach ball of death, then the hard drive is fu.k.d up. You then have to open up the computer and install a new hard drive and re-install the OS. Good luck old chap. Cheers.
Dec 31, 2009 | Office Equipment & Supplies
I am trying to install the OS but the computer does not recognize the hard drive to begin the install.
When you get to the opening window of the software launch on the OS disc, you can find access to the Disk Utility and you can mount the drive via the Disk Utiltiy program.
You can also format it if needed.
K
Oct 17, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Installed a new internal hard drive and when I try to boot up the machine does not recognize the new hard drive. There is no item in the select which drive to load from.
Boot off the install disk with nothing else attached to the PC. ( external hard drives especially ).
Choose ‘Terminal’ in the ‘Utilities’ menu
Then (substituting the correct values for your setup), type:
diskutil partitionDisk /dev/disk0 1 GPTFormat JournaledHFS+ my-hard-disk 111G
It’s all one line and hit return at the end.
You should see progress information, followed by a neat table giving the new formatting that has been applied.
‘/dev/disk0’ is how the operating system refers to the first whole disk in the system.
Then, the ‘1’ here signifies that you want one volume only on the drive.
Then, replace ‘my-hard-disk’ with the volume name you want to use. This is the name of the disk as it appears in the finder.
Replace ‘111G’ with the size of the disk in gigabytes. It’s usually about the same as the disk, and as the partitioning software will stretch a single partition to fill the disk it doesn’t matter too much. 111G was the value used for a 120GB HDD, because I knew that it wasn’t really 120GB.
Hope this is of some help.
If not a solution ( hard one to do over the net :) ) hopefully it will point you into a solution.
Locked G3
Time to completely erase the hard drive.Start up from your install CD with latest version that will run on this Blue and White.. Don't expect to save any existing files. Just do a complete erase and reinstall via disk utilitly and then your os disc... let me know how it goes..
Mar 14, 2009 | Apple Power Macintosh G3 (Blue and White)...
Replaced HD on ibook Clamshell, now can't boot
The Clamshell iBook 366 doesn't officially support Tiger, but can usually be installed using 'XPostFacto'. (You can get it here http://eshop.macsales.com/OSXCenter/XPostFacto/
It's open source software but you still might find some aspects of Tiger don't work.
Jan 12, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Apple iBook Mac g4 Notebook hd doesn't appear
You have a hard drive issue, this is why it freezes. DO you hear clicking sometimes in the laptop? I would get your hard drive looked at by a tech.
Jun 09, 2008 | Apple iBook Mac Notebook
New User
You need to run the disk utility program to repair disk permissions. It is in the applications folder, in utilities, first aid. If the iBook won't let you run that program, you will need to boot from the Tiger CD and run the disk utility from there.
The final revision of Tiger is 10.4.11. Once you have your system in order you will want to check for Apple updates. This can be found under the apple menu at the top of your screen or in system preferences.
Dec 12, 2007 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook G4 Mac Notebook Logo
179 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
