Question about Dryers
Fisher & Paykel ED52 electronic tumble dryer. Since several power failures two days ago, when power button is activated & "start/paus" button pressed it beeps 4 times & won't work. I have unplugged from the power point & left it several minutes then re-connected but still the same problem. The owner's manual has no troubleshooting section. What now?
I found advice on the Fisher Paykel web site that suggested the problem could be the door lock. In fact the catch had not properly engaged & when I fixed that the dryer worked.
Posted on Jun 19, 2008
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Hi i have an old fisher & paykel whiteway 405 dryer and its making an awful noise and wont tumble. any suggestions
I have never worked on one of these but I have a manual I can give you. I imagine it is a bad roller or idler.
Happy holidays DEGX1 repair manny
Dec 04, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Dec 17, 2008 | Fisher and Paykel DEIX2 Electric Dryer
Dryers Logo
404 people viewed this question
Top Dryers Experts
