Disc Boot Failure
I am unable to log onto my computer "disc boot failure insert syst rom disk" appears is this a major problem or one I can easily rectify myself? Do I need to call in an expert?
  • luisurdaddy Oct 21, 2008
    my message at start up reads " boot disc failure, insert system disc and press enter".
    No more warranty for me HP only gave me 1 year.
    Please help!
  • 426 Answers
You might be able to fix it your self, either your harddrive has failed... Your harddrive is not set to boot in the bios, or something came loose if you need more info please feel free to email me my email address is fixya (at) whypayforhelp(dot) org
Posted on Jun 19, 2008
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Comp frozen.will not connect to windows 7..error while initializing the NIC
PXE ROM boot is a network boot that kicks in when all else fails. If you have or can borrow a Win7 boot disk, watch the screen closely when powering on the computer and it will tell you which key or keys to press to force a boot from the the cd/dvd rom. If you can boot from the optical drive , it may give you the option to repair Windows. READ THE SCREENS CAREFULLY AND CHOOSE WISELY - if you do not you can overwrite windows and ALL of your personal data. IF you have a hard disk failure, windows should tell you so...
Feb 06, 2014 | Computers & Internet
How can I a boot disk system failure on my Asus without a system disc?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
When i turn my computer on i get a message that says, disk boot failure, insert system disk and press enter
Your boot file on your hard drive may have been corrupted. You need to start the computer with your operating system disc in the drive, and hopefully it will be able to repair your operating system. good Luck!
Jul 17, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
Trying to run recovery disc on computer and cd rom isn't reading
I see this as one of 2 possible failures.
  1. Optical drive failing. Take out the Hard drive, see if the recovery disk, or another bootable disk will boot. If no change, replace the optical drive.
  2. Hard Drive failing. If the system will boot to a CD with the HDD out or if replacing the optical drive has no change, then the HDD is the next logical failure point.
Apr 02, 2009 | Compaq Computers & Internet
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
Unable too logg into the system
sounds like a hard disk issue try booting from the original s install disk . the see if you can reapir the installtion
if it still can recognise the disk you probably have a hard disk problem. Eithe buy or get a techical person to call out and check the hard disk for you.
if you have win xp boot to the cd then choose repair at the first menu , when you get to the dos screen type in
chkdsk /f and let it do what it must to complete.
hope this helps
Jan 02, 2009 | E-Machines Emachine T5026 power supply **...
Disk boot failure error while booting
What does it says???Cant find hard drive or what???
Jul 18, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
