Question about Motorola Cell Phones
The only key on my cellphone that works is the on key. I would like to get my numbers that are stored, and my texts.
    Sergeant:
    Champion:
  • 297 Answers
The plex that connect to mother board of your cellphone is broken allready , that only the button is on working. Change the key plex and it will work again is not so expensive.
Posted on Jun 19, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
My samsung captivate is not receiving text messages. Please help!
Hi, please make sure that you added the Message Centre Number in the Cellphone. You can get the message centre number by contacting Customer Care of the Network Carrier. Then, add the Message Centre number in the Message Settings of the Cellphone. Now you should be able to receive text messages.
Apr 07, 2011 | Samsung Captivate Cell Phone
I got my Nokia phone wet. Dried it. Heated it slightly, but the screen has died/so I cannot access the menu. the phone still rings, Texts come but I cannot see them as the screen is grey. The phone...
Hello There! I think the LCD of your phone got affected by the incident. Since your phone is a Nokia product, you can install the driver for N-7250i into your computer so you can use the PC Suited Program. Once you have installed it, connect the phone and then start using the PC Suite. It will allow you to access everything. Phone book, Messages, photos and music. Look for the synchronize button and create a back-up for your files. It is much better to just copy the files, (e.g photos, tones) so you can still store and view it on the computer if ever your cellphone will no longer be fixed. I suggest you also go to a cellphone technician to check your LCD screen and make a remedy for your phone.
Have a nice day ahead! ^_^
Feb 02, 2011 | Nokia 7250i
My cellphone nokia 7610 cant send sms but it can only receive sms and it can make a call.. i dont know what should i do.,..
You can not send messages because the message centre number stored in your mobile may be wrong.
Please enter the correct message centre number.To get the correct message centre number please call your service provider and they will provide you the number.
Menu > Messaging >Options >Settings > Text message >Message centres
Thank You
Aug 17, 2010 | Nokia 7610
Text view settings
Make the number in the contact book exactly as the number shows up on the text
Jan 26, 2010 | Samsung SGH-L700 Cell Phone
The key number 5 on my cect c1000+ phone just
Sir,
Your cellphone need to be repaired through main keypad chip usually it get fixed from just Service. This also ocurs when too much carbon jam the circuit of the cellphone.
Aug 30, 2009 | Cell Phones
How cani I reformat my n70?
to reformat your n70, just off your cellphone,,after you off,simply press and hold the green key,asteris key and number 3 at the same time and then turn on your cellphone...
para marepormat ang iyong n70, patayin ang cellphone,,pagkatapos patayin,ipress ng sabay-sabay ang green key,asteris key at number 3,,habang nakapress sa tatlong key,sindihan or buhayin ang iyong cellphone at intaying mareformat...huwag bibitawan ang pagkakapress sa tatlong key hanggat di pa narereformat....
Mar 24, 2009 | Nokia N70 Cellular Phone
My keys are messed up on the sidekick3
ebay has that problem solved . my menu button is missing and got one from ebay for $10 and it worked nooo problem. my first going to a store was the worst idea ever. avoid wireless store who sell cellphones. they make u pay 20 to $30 MORE THAN U ORDERING IT ON LINE. DONT GO TO YOUR SHOPPIN AREA TO SOLVE YOUR CELLPHONE PROBLEMS.MY STORE CHARGE ME $40 more.
Sep 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
How do I save text to print later
First store the text pressand hold down the stor key while typing a number 1-99, the store light will blink, begin typing when the store light stays solid. To close the storage press and release the store key To play back insert paper press play key + the number you used to store the text 1-99 playback should start when you release the keys.
Jun 18, 2008 | Lexmark Wheelwriter 3500 Typewriter
Cell Phones Logo
32 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
