Question about Cameras
My digital camera name FinePix A340 has a red symbol that looks like a battery flashing. It flashes for a few seconds and then the camera goes blank..I have put new baterries in it. Energiser rechargeable AA NiMH 2500 it still does it..whata the problem..
  • Susie Blackman Jun 19, 2008
    sorry how do I change the setting once the regular batteries are installed...maybe I need a manual which I haven't got...I'll get some regular batteries tomorrow can you recommend what type of battery I ask for..
  • Susie Blackman Jun 20, 2008
    Thankyou for fixing my problem I am so happy,my camera is now working again after months of wondering . Every time I thought about the problem I thought of big dollars to fix it..Thankyou sooo much..
    Scholar:
  • 68 Answers
FinePix A340 Zoom has been specifically developed to reduce power consumption.The FinePix A340 Zoom has been specifically developed to reduce power consumption. The two AA alkaline batteries supplied with the camera deliver an impressive 220 shots under normal conditions.* Ni-MH rechargeable batteries are also available as part of the Fujifilm accessories range for even better battery economy, providing approximately 110 additional images before charging is necessary.
* Pictures taken with LCD screen off, and flash on for half of the pictures taken
Possible Solution:
1: Remove your memory card and check if it would have the same issue. If resolved then reformat or replace memory card.
2: You can try to use dift battery aside form what you are currently using. Your cam FinePix A340 is a cool cam. AA NiMH mightve reached its peak. To isloate what the issue is you can try a dift type of battery and let see what will happen from there.
3: If all fails.. visit this website:
http://www.fujifilm.com/support/index.html
You might as well upgrade your firmware by clicking on the link below:
http://www.fujifilm.com/products/digital/download/a340/fupd.html
That is for Update Ver.1.22
If you may have additional questions pls feel free to ask .
Cheers.
Posted on Jun 19, 2008
  • 4 more comments
  • ian prince garvilles
    ian prince garvilles Jun 19, 2008
    oops... for updates check this out :
    http://www.fujifilmusa.com
    Cheers
    and ...hey . you can check this very useful manual .
    http://www.fujifilmusa.com/shared/bin/A3...
    cheers
    OR
    The information above is a guide for photography mode. Depending on the camera mode and the type of batteries
    used, the transition from “C” to “V” may occur more quickly.
    Due to the nature of the battery, the battery low warning may appear early when the camera is used in cold
    locations. This is normal. Try warming the batteries in your pocket or a similar location before use.
    ✽ Battery level warning
    1) The camera’s estimation of the remaining battery charge varies greatly depending on the camera operation mode.
    Consequently, even if “C” or “V” is not displayed in Playback mode, one of them may appear when you change
    to Photography mode.
    2) Depending on the battery type and the level of charge in the batteries, the camera may run out of power without first
    displaying a battery level warning. This is particularly to happen when batteries that have run out of charge once are
    re-used.
    In situation 2), immediately load new or fully charged replacement batteries.
    Power save function ◆
    When this function is active, it turns off the LCD monitor to reduce power consumption if the camera is not
    used for 30 seconds (➡P.50). If the camera is then left unused for 2 minutes or 5 minutes, the Power save
    function turns the camera off. To restore power to the camera to take pictures, briefly close and then reopen
    the lens cover. To play back images, hold down the “Playback” button for approx. 1 seconds.
    Hey,
    Before buying your new battery . CHeck this out .
    Its very helpful.
    Anyway with the battery:
    Hers most compatible with your battery :
    2AA alkaline battery OR NH-10 Nimh.
    Duracell or energizer would do fine. BUT why regular batteries when you can purchase rechargables NH-10 Nimh and wont have any issues with it anymore.
    Good luck and hope everything that id post would help you.
    PLs check your manual as posted above for more detailed description about your cool cam.
    Pls dont forget to rate me Fixya. :---}
    Cheers.
    As what ive researched on your cam unfortunately theres no way for you to change battery type mode on it Regular battery is the perfect option But its always cost effective to use a rechargeable battery - just make sure you would have more time to charge it and when your cam is not in use better to discharge you bat from you cam as it would still generate power.
    Pls refer to he manual i posted as it is very useful.
    Cheers.
    ian prince garvilles Jun 20, 2008
    Hey,
    i am so happy knowing your cam is working now.
    Pls dont forget to rate Fixya.
    Best Wishes
  • 426 Answers
You need to use regular batts, then change the setting to rechargable
  • Lee N.
    Lee N. Jun 19, 2008
    because the rechargables only give off 1.2 volts per battery and regular batteries give 1.5 per battery, so if you had 4 batteries that are rechargeable its only 4.8v while standard batts would be 6v your camera should have a setting to change the battery type
  • Lee N.
    Lee N. Jun 19, 2008
    just use standard batteries there should be a setting under the power options
With a new set of batteries in camera the red battery low symbol
Try cleaning the contact points in the battery compartment. If one or more of the contact points are soiled, the camera will react like that. If the problem is due to a short circuit, the batteries will get very hot, if they are discharged after a few seconds.
Mar 02, 2010 | Fuji FinePix S7000 Digital Camera
Why wont camera flash when taking pics? I have new batts
select the flash mode properly ,fully charged mode/auto charged if u do not get fired the flash unit is defective,to be replaced
Mar 02, 2010 | Fuji FinePix A340 Digital Camera
Need to suppress flash
The flash mode button is located to the right of the zoom button. Press the button several times to cycle thru flash modes.
Suppressed flash is the round symbol, where the lightning symbol is crossed over.
Jan 14, 2010 | Fuji FinePix A340 Digital Camera
Fujifilm takes Disorted photos
How old are your camera and memory card? Both will eventually wear out. Digital cameras are generally good for so many shots. The same goes with the cards. I would personally try a new card and see if it helps.
Jul 25, 2009 | Fuji FinePix A340 Digital Camera
FINEPIX A340
the only wayi found to make the card accepted is to upgrade the firmware software, this can be downloaded from fuji website, and extract the file and copy it in the initial memory card supplied with the camera, then put bnewly charged batteries or ac adapter and on the camera holding the disp/back button. then it will show the option for the update, and then click ok . after installing ne firmware switch of the camera and put the new xd card on the camera and format the card. this will enable you to shoot inthe new card.
Aug 30, 2008 | Fuji FinePix A340 Digital Camera
FinePix A340....Flashing lines across LCD screen
I have the exact same problem !!! I wish someone would be able to help with this one !
Mar 25, 2008 | Fuji FinePix A340 Digital Camera
Error
Here is where you can download a copy of the manual from:
Fuji S2 Manual
This is what the manual says about your error:
If FEE in in top display: "CPU Nikkor lens other than G-type
is not set to its minimum aperture. Fix: Set lens to minimum aperture."
If FEE is in viewfinder: "Attached flash is not set at TTL
Auto Flash in “P” mode. Fix: Set the external flash mode to TTL, or set the camera’s exposure mode to “S”, “A” or “M”."
Are you using a flash that attaches to the camera?
If not, then the problem is with the aperture setting. It looks like you would have to set the camera dial to M, for Manual, and use the ring on the lens to set the aperture.
The low battery symbol looks like a battery, all black when charged, half-black as power goes down.
This looks like a nice camera, hope I was able to help.
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
How do you turn the flash off?
christinaaa: You must pressed several times the FLASH button until the regular FLASH ICON (The Thunder Symbol) appears inside a circle. This mode is called "SUPRESSED FLASH"... SithPitt
Jul 04, 2007 | Fuji FinePix A340 Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Cameras Logo
127 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
