Back to:
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Yamata FY7568 Machine not sewing
posted by otissv on Jun 19, 2008
I just bought a Yamata FY7568 sewing machine and it is not picking up the bobbin thread.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 23, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Make sure the correct needle is installed on the machine. Domestic needles will have one flat and one rounded side on the shaft. Make sure the flat side of the needle is on the back and the groove on the needle also being to the back.
You might also want to make sure the tip of the needle is not broken.
Other than that, your machine could be out of timing.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Yamata FY7568 Machine not sewing:
I don't want to Accept this solution
Solution #2
posted on Jun 21, 2008
Not Rated (0)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1291 votes
Make sure you have the needle in the correct way round, failing that it will need retiming and if it is in warranty I would get it done as soon as.
Thank You!
Can you Help with these Sewing Machines problems?
PfaFF Creative 7570
the bottom thread not precise, making loose thread? have...
Singer 7466 Mechanical Sewing Machine
I can not get the needle to pick up the bobbin thread....
Singer 7462 Mechanical Sewing Machine
old model singer 275k tried to use it the other day and...
Brother CS6000i Computerized Sewing Machine
While out of town, my sons dog chewed the ******** of the...
Singer 7442 Mechanical Sewing Machine
How do I attach a Singer Free Motion/Darning Foot foot...
Loading problems.
Repair Service
Find Sewing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
