To Recover from the dreaded E-01 ERROR simply follow my
RS232 loading instructions But REPEAT step 4 and 5 Twice BEFORE moving
on to step 6
NOTE
ALWAYS Unplug your receiver BEFORE disconnecting Or Connecting your Coax
cable Or RCA cables !! FAILURE to do so WILL damage your receiver !
1) Download and unzip both the ( COOLSAT7000_FAC_V0111 ) and NorW latest release
2) Connect your receiver to your computer using your RS232 cable.
3) Open your Coolsat 7000 Loader click the file button and load your Coolsat_7000_Fac_Vo111 into your loader
4) Timing is everything on this step ! Put your mouse over the download
button and as soon as you turn the Back power switch on your receiver ON
click the download button
If your to slow it will NOT load and you must Repeat this step !
5)When your receiver reboots itself Or you see this ---- turn off the
back switch and reconnect it to your TV then click Menu on your remote
and then go to Installation screen and select SYSTEM RECOVERY and click
YES to (System restore to Factory Default) when the factory reset is
finished set the Language of choice and then set your time zone. After
setting the time zone the receiver will ask if you want to Auto detect
your satellites and switch settings. Say NO at this time !
6)Now Repeat the First 5 steps to load the Latest Coolsat7000_NorW-bin !
BUT this time say YES to Auto Detect and it will auto set your LNB type
and switch settings and then scan All the satellites your pointed at !
NOTE
i have a epson sx215 - delicious.gifloads/images/delicious.gif" alt="delicious.gif" class="h_mi" />i have a epson sx215 - quote.gif
SOURCE: when i turn my printer on error message occurs
Power off the printer, unplug the power cable.
Lift the scanner lid, check for obstructions that might be blocking the print head.
Close the lid, reconnect the power cable and power on the printer.
If it still says E-01, please contact your local service center or the store where you purchased the printer for your warranty options.
