Question about Compaq Presario 700 470024-192 Notebook
Drivers Disappear Using SONAR 5.0.1 on Windows XP64, with Edirol UA101 USB interface. The Input and Output audio drivers disappear. I open Sonar, insert audio track, select audio input channel menu, it says Edirol, but there is nothing in the list, no left, right, stereo etc. I look under the AUDIO menu, under drivers, nothing so I reboot, open Sonar, look under the Audio menu / drivers... then all the drivers are there. I can insert an audio track select Left channel and record and playback. Then I go to insert a new Audio track, can't select input channel, I look again at the Audio menu / drivers no drivers???? Anyone have any thoughts, thanks. My computer the audio cannot desapiar so pls help me to to boot
  • 1 more comment
  • sumith1 Jun 19, 2008
    in my pc the Audio drivers can't disappears
  • martinengo c Jun 19, 2008
    troubles with audio drivers
  • Anonymous Jul 08, 2008
    SAME PROBLEM
    Scholar:
  • 174 Answers
Its a fight between 64 and 32 bit versions. Audio codec is not so compactable with your sound card sysaudio file You need an updated driver which is compact-able with direct x latest can solve your problem
Posted on Jul 19, 2008
I can't get my Behringer XENYX X1222 USB to control any of the faders within Sonar X1 Producer.
It may require the driver to be installed for the Behringer, or re-installed.
Go into the settings section of Sonar and if you can "De-select" M-audio as the default controler, or you may need to go through the preferences of M-Audio to find it.
To me it sounds like a driver is missing.
Jan 30, 2012 | Music
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
Sep 23, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Cakewalk Sonar - Edirol UA-1000 crackles on playback!
That's a latency issue it sounds like.
There's a slider under "Audio" .
Move it in increments towards "slow", test it as you go.
Leave it at the highest setting possible that doesn't crackle.
I've heard this so bad that it sounds like a gun going off.
It scares the Hell out of you when it happens !
Jan 20, 2009 | Edirol UA-1000 External Sound System
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
Canecting US122 with Sonar HS4
Hey there,
Try the latest US-122 driver (3.4.0), you can get it here:
http://www.pcmusic.org/software/version.php/lang/en/id/10422/
There might be a latency problem with the Asio4all driver too, try the US-122 16bit or 24bit driver, they are actually Asio drivers.
Also navigate to Windows Control Panel and make sure that a Windows Media Player Update hasn't minimised the Wave Control Sound.
Good Luck and have fun
Chris (ziraffa)
Mar 02, 2008 | Tascam US-122 USB Audio/MIDI Interface...
SONAR LE NO AUDIO
Microsoft re-engineered the audio bus for Windows. HD Audio is hardware specific, in the sense that specific drivers have to be written to make a piece of hardware compatible with it. Roland is not writing a driver for the UA 25 because they want you to buy an UA 25EX. Get my drift? The UA 25 uses Kernel Streaming, the old way, which exists in parallel, sort of, with the HD Audio bus. But the new ways are always prioritized over the old ways in software, so there is bus contention (glitching).
To fix this there are a few things you can try:
1) Roll back to SP2. SP3 implements the HD Audio bus, so don't use that implementation. If your laptop has an HD audio sound card then I doubt it would work, but your UA 25 would.
2) Try ASIO 4 ALL. This fixed everything but glitching in VST instruments.
3) Reduce the amount of stuff your computer is doing. Optimize your OS by turning off the cute shaded windows and desktops and various processes that you don't need to see or use. There are sites for this. This increases available RAM, CPU time, etc.
4) Video hardware acceleration, sometimes, would fix bugs in software left in by not so clever programmers.
4) You can always just give-up and go along with the bastards and buy new stuff and toss the old stuff.
-SQA MGR
Sep 04, 2007 | Edirol UA-25 External Sound System
Compaq Presario 700 470024-192 Notebook Logo
147 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
