Question about Apple iPod MA446LL/A MP3 Player
Apple ipod not connecting to itunes (80 gb 5th gen)
I recently bought a used ipod. It doesn't appear in itunes when I plug it into my computer. I wanted to reset it, but since it didn't connect to itunes I tried first putting it in disk mode. This worked. I then plugged it into my computer. It popped up on itunes with a message that said my ipod was corrupted and it needs to be reformated. I pushed the restore button. I progress bar appeared but soon afterward an error message popped up with an unknown error. I think the number (1418) was listed. I'm not sure if that was the correct number. Is there a way to fix this problem. I would just like to retore it.
  • Apple Master
  • 13,433 Answers
You might have to send the ipod in for service or if the seller said it was fully working - geting a refund for it.
Try this page
if everything on that page desn't solve the problem
then here is the online service assistant
Posted on Jun 19, 2008
What gigabyte is my iPod
iPod touch (5th Gen, 16 GB, 2014) 1.0 GHz* Apple A5* Intro. June 26, 2014* Disc. July 15, 2015 Order MGG82LL/A* Model A1421 (EMC 2600*) Family 5th Gen ID iPod5,1 RAM 512 MB* VRAM None Storage 16 GB* Optical None Complete iPod touch (5th Gen, 16 GB, 2014) Specs
Nov 20, 2015 | Apple iPod touch
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> b> b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
I forgot my i pod touch lock code
Try connecting your iPod with the first computer you used it with and open iTunes. If that doesn't work you will have to restore your iPod
Oct 01, 2011 | Apple iPod touch Second Gen (8 GB,...
Bought a brand new ipod touch. Uploaded my music using itunes. Now the ipod won't turn on.
connect to computer go on itunes click ipod click restore might need software update hope i helped
Jul 05, 2010 | Apple iPod touch Second Gen (8 GB,...
I got a new 5th gen ipod nano not reconised by itunes
I found this article on apples web site I thought it might be helpful
Apr 14, 2010 | Apple iPod nano 5th Generation
Ipod woulnt connect to itunes
Reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Then connect it to your computer and see if it is recognized by iTunes.
If not, try other USB ports on your computer, especially any on the back panel.
Dec 29, 2009 | Apple iPod nano
I bought a used ipod touch 32G and when i got it home it came with no software. the box said that the software would automatically take me through a tutorial to set it up with itunes. when i plug it in the...
this is a simple solution all you have to do is download the latest version of itunes from the apple website and install it after its installed then connect your ipod and itunes will guide you thru the rest
Oct 25, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My screen is on language selection and does not let me scroll or anything i think its frozen.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    Hope i helped you.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My computer does not recognize my ipod shuffle when I plug it in?
connect the USB Connector properly and install Itunes to recognized your IPOD connected itself.
here is the link to download new itunes
Jul 21, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
