Question about Intel Motherboard
No display, no start up beep, no post and no boot
i just assembled a pc
intel core 2 duo 2.66 ghz e8300
msi p7n sli platinum
xfx geforce 8800 gt (using one)
2x1 gb transcend 800 mhz
360 gb sata
19" samsung sync master.
500 w power supply
well when i plugged in the power supply and pressed the power button, the fans and all strted to work but ther is no display on the monitor. there was no bios on the screen. no beep of the pc booting. the fans on the cpu and cabinet and graphic card were working. but no display.
i checed the monitor with my laptop, it wrked fine.
please help!!
also is it mandatory that the smps will have a 8pin power supply..i seem to have only one 24 pin power.
also i have a asus lite scribe fixed in. would the drive work only when O/S is installed..it didn work even when the fans were running..
m using a div-i dual to vga converter for the monitor.
hey another thing. i have a wireless miscrosoft keyb and mouse. can it work even when no OS in installed??? else how do i input commands?
  • 4 more comments
  • vinay goyal Jun 19, 2008
    please answer this too
    "hey another thing. i have a wireless miscrosoft keyb and mouse. can it work even when no OS in installed??? else how do i input commands?"
    hi thnks fr the help
    please help me with this too
    "also i have a asus lite scribe fixed in. would the drive work only when O/S is installed..it didn work even when the fans were running?" when will it strt working?? the tray didn come out whne the fans werer runing
  • vinay goyal Jun 20, 2008
    hey,
    but the receiver works with my laptop without installing any drivers for the receiver.
    else do i get a ps2 port for keyboard and mouse.?
    hey m lucky enough to have a guru answering my problems..
    i will buy a ps2 keyboard and mouse tomo..
    also der is a prob with the disk drive.
    i neeeded to know if the tray shuld come out when the power is ON in the compu. well u know my prob with the booting..i pressed the botton on the disk drive but no tray came out?
    does it have to do with the bios or is it independendant. i have checkd the power cable, thts firmly in plce...
    help me here too.
    the e market is far away from my house. i have only tomo till next weekend to get things going.
  • vinay goyal Jun 21, 2008
    hi i got the drive prob soreted out..to an extent..
    when ever i connect the ide cable, it doesn respond. but without the ide cable its opening and closing ..
    wht can be the prb?
  • vinay goyal Jun 22, 2008
    hi worldvet,
    i have got it working..finally!!
    thanks a ton fr ur help..
    i couldn get a molex converter but the system strted working by only 4 pins i/o 8..
    also the drive and cables were ok...as soon as the system booted and bios appeared the optical drive too strtd working...
    thnku so much fr all the help and time..
    really appreciate it.!!
Hi thnks fr the help
Posted on Jun 19, 2008
    Guru:
  • 859 Answers
You need a Molex power plug (same as for your standard IDE hard drive or DVD drive to an 8pin adapter. A common product. If you can't get it locally.
Without this the board won't boot as there is insuffcient power on the motherboard to drive your display adapter.
Here is the link to the product at crazypc.com.
Also, if you have onboard video too, make sure the bios setup pages have the property set for primary display adapter to Add-in/PCIe.
Regards,
Worldvet
  • 3 more comments
  • Glenn Rogers
    Glenn Rogers Jun 19, 2008
    No your mouse and keyboard won't communicate until on boot the OS has loaded the drivers for the communication receiver attached to your PC.
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 20, 2008
    You don't have to install drivers for the these to work unless you have windows 98, unless you have multimedia keys on your keyboard you want to associate them with special functions; this is most true if you have a Microsoft keyboard and mouse setup as those are built in along with Logitech.
    Once your transceiver is plugged into USB and you sync the channels everything will work after the OS is completely in place.
    When I have to setup a new PC I usually use a PS2 Keyboard and Mouse to get the OS installed and then in this order you install the display driver first and then a USB Mouse and Keyboard, but we techs always use a method and you will want to follow that too. If you have a PS2 keyboard and mouse and have just built a system use those to get the OS setup and activated, install the updated Display drivers, next the other devices usually the network drivers and then we add one device card after another rebooting and installing those drivers one at a time. Thats how we do it.
    If you add all device cards at once it hard to pin down a problem. This we all learn from the doing over the years, 20 in my case and most all techs on this board will agree who have the same amount of experience.
    Be aware there are many techs on this board who we still consider rookies with less than 10 years experience. Most of us have Linux setups and own at least four computers and at least one laptop usually two or more.
    So anyway, any more questions just ask away using the comment box and if you want to confer with another tech on this thread I'll invite one in who has the reputation and experience where we can both get you going if you want to consult with more than one of us... we don't care. We're only here to help someone like yourself get your first build done right the first time and not have to learn by mistake.
    Regards,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 21, 2008
    That is hard to comment on and I apologize for not getting back earlier. My business had me out of the home most of the day.
    Your optical disc drive bay should open whenever power is on. There is a hold in the tray this is meant for a straightened Paper Clip of heavy weight to be pushed in, you will feel resistence and then a release at that point use the other end of of the paper clip to open the drawer, then use the button to close it. That may resolve a stuck gear.
    Worldvet
  • Glenn Rogers
    You could be attaching the cable upside down, but that isn't the only thing as you probably have it right, its worth double checking.
    At the back of the DVD player is a jumper that can be in one of three positions with a guide stamped on the top of the housing. They are Master, Slave and Cable Select.
    On your new system I would set it at Cable Select (CS) and or depending where on the cable its attached. At the end of the cable you set it to Master, if its the second (middle) connector you set it to Slave. Some times these things matter and sometimes they don't. I'd check it at the board also. But today all these cables are keyed so you don't get it upside down, but its worth a look. And, I'd connect the DVD player to the end connector and jump the pins for Master and see it that works.
    By the way, its getting late here and I'm about to fall asleep. So I may not get back to you until late tomorrow as I have a lot of outside calls to make on peoples computers here where I live.
    Good night,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 22, 2008
    Its been my pleasure.
    Thanks for using Fixya
    Worldvet
4 Suggested Answers
  • 287 Answers
SOURCE: msi motherboard
@ vinay2412 - YES you need a PSU wil either the 4 or 8 pin molex connector to power the motherboard correctly
the lightscribe drive will not read a DVD or CD until you boot the PC correctly
the wireless k/b will not work until you load the drivers etc. you need a PS2 or USB k/b to get thing going first until the OS is running and you can install drivers
@ shaikh27
your error suggest you need to load drivers from the motherboard driver CD. do you have this?
Posted on Jul 17, 2008
  • 11800 Answers
SOURCE: I want to buy a new rig , main purpose is to use
The processor is too weak - get at least an i5, best would be a quad core i7; the hard drive will be filled faster than you thing - bigger is always better; get some faster memories - at least 1666 MHz, 4 GB is bare minimum, get a 64bit OS and 8 GB for real performance; the power source is at the limit - for best result get one of 600W; as for the video card the best for photoshop is Nvidia Quadro CX, even ATI Fire will be better than any gaming card.
Posted on Jun 13, 2010
  • 115 Answers
SOURCE: Hi i am using windows
it is normal and if you have dust problem then clean it
Posted on Jan 15, 2011
No post no beep
check your hard drive and make sure it's connected properly and set for master, not slave.
Feb 14, 2010 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Bios don't boot on p7n platinum sli
check the voltage on the power connector going to the hard disk.
it should have 12volts in red and black wire and 5volts on the yellow and black wire.
the main problem the optical and hard disks can't be recognized is the low voltage supply the drives gets.
Apr 13, 2009 | Intel Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Need advise for upgrating graphics card
GET THE NVIDIA G FORCE 8400 GT IT IS THE NEWEST CARD AND IT WILL RUN EVERYTHING YOU HAVE.
Mar 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Is it compatible
Hi playboyalive, to answer your question! (Yes) the,
XFX nForce 790i Ultra SLI Motherboard will support Intel's core i7 extreme edition multi-core 3.2GHz CPU. The board can go higher. The highest tested by XFX is Intel's 3.73 GHz multi-core CPU. You can see all supported CPU's at the XFX link below;
http://www.nvidia.com/content/nforce700i/nForce_Intel_CPU_List.pdf
The above link was opened from this XFX link; http://www.nvidia.com/object/product_nforce_790i_ultra_sli_us.html
Thank you for using FixYa playboyalive!
Mike
Feb 04, 2009 | ASUS NVIDIA nForce Chipset A7N266-VM...
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Msi motherboard
@ shaikh27
Jun 19, 2008 | Intel Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No post no beep no video
you sure that the 4pin power connector coneected to your mobo
Sep 12, 2007 | Computers & Internet
Intel Motherboard Logo
734 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
