Question about NAD Audio Players & Recorders
NAD 7225 PE STOPPED WORKING, FUSE BLOWS WHEN REPLACED, REPLACED OUTPUT TRANSISTORS, FRIED RESISTORS, ONLY ONE CHANNEL WORKING
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Hello sir
you can go throughh this
www.Fixya.com/Nad+Manual
Posted on Jun 19, 2008
  • 1,879 Answers
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Brigadier General:
  • 6,966 Answers
A couple of things to check:
1. check the speakers;
2. since one channel is working, with no signal input and volume down, compare DC voltages of the left and right channels using the operational channel as basis;
3. doubt if problem involves power supply since as you posted the other half is working.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 1,512 Answers
I know these amps well. The power envelope circuit has probably failed as well.
  • 3 more comments
  • Graeme Ross
    Graeme Ross Jun 19, 2008
    I also change out any bd139 transistors for 2sd669 also, as the bd transistors often caused them to self destruct. I also reccommend replacing all the driver transistors as well as the output, and checking EVERY transistor in the DC coupled chain. Any transistor in the output stage could be causing it to malfunction. you also need to setup the bias correctly after any work to the output stages.
  • Graeme Ross
    can you tell me what parts you have replaced?
  • Graeme Ross
    The power envelope circuit supplies a "boost" voltage to the output stages. When output transistors fail, these transistors also go shorted, usually apparant by strange differing voltages on the collectors ot the outputs. I strongly reccommend that you softstart the amp with a variac if you have one at about 30% mains voltage to allow you to fault find without blowing fuses or damaging the new parts you have just fitted.
  • Graeme Ross
    OH, use a 2sb649 for the complementary transistor to the 2sd669. Change the bias control transistor(if its a bd139) mounted to the heatsink as well.
  • Graeme Ross
    Graeme Ross Jun 30, 2008
    How did you go with the amp repairs?
    robotek
Hi ihave nad 304 it keeps blowing 5 amp fuses
Most likely caused by a shorted output transistors on at least one channel + possibly some other components they took with them... but maybe you are lucky and you have a shorted power capacitor or something.
Mar 14, 2015 | NAD Audio Players & Recorders
I have a DTR 7.1 Integra receiver and it goes into protect mode when turned on. Is this something that can be fixed by myself or does it need to go to repair shop.
If you have a volt meter you may try and repair it yourself. First however disconnect the speakers and see if the set still goes into protect. If so you may have shorted output and drive transistors. There will be open resistors near them as well. You can compare the bad channel with a nearby working channel since normally only channel shorts out at a time. Always replace outputs in pairs since they in push pull configuration .
Oct 02, 2014 | Integra Dtr-7.1 Av Receiver Surround Sound...
One (right) preamp blow! I've located the problem to the right C160 module. When disconnected everything seems fine. Diodes and transistors are apparantly ok measured onboard as are all resistors and...
hi...
transistors are not ok on the C160 module.
replace all the power transistors and emitter resistors for that channel.
www.bdent.com and www.ceitron.com are good for transistors
Sep 30, 2010 | NAD C370 2-Channel Amplifier
Channel B protection light is on and it blows 1 of 4 fuses. channel A runs fine --- help !
You likely have some semiconductor part failures on the side that is blowing fuses.
Put a 100 watt lamp in place of the fuse that is blowing so that you can test parts. The lamp will limit the current to a safe value and allow you to weed out the bad parts.
EXPECT that the power amp transistors (probably BOTH sides are bad (shorted) and that the probllem may have fried driver transistors and associated resistors back a stage or two. DO NOT replace the lamp with a fuse until the amp BALANCES with the lamp in place... one bad part left in fries the whole lot again!
Jan 06, 2010 | Music
Behringer PMP5000. The Powered Output B dead
Make sure the three position slide switch is set correctly for the stereo usage, that is NOT the bridged OR the Mon mode.
MAKE SURE the pan pots are set to middle as they control the spit of the audio to the two channels.
This is a class "D" amplifier (switching) and there really isn't any fuse for a single channel.
MAKE SURE your speakon connections are good by swapping your speaker cables.
I repaired my unit and had to do that without schematics... Behringer will not give them out. Mine had a severe arc-over on one side power amp taking out about ten transistors and diodes and one swithcing regulator chip. Had to cut out the "cancer" of the burned board.
This unit uses a complementary output stage that is made up of one transistor on one side and a pair in parallel on the other. This drives the inductor/capacitor filter... I think the switching frequency is between 100KHz and 1 MHz as I recall. All those transistors were gonzo. It also fried the main power switching transistors in the power supply, several smaller transistors, diodes, and the switching regulator chip.
Also two 10 ohm power resistors were fried. They soft start this unit by charging the main caps via two resistors that limit the inrush current.
A small switching supply has to come up first before the main supply which sends the DC to the amp section.
Nov 23, 2009 | Behringer Music
NAD 302 stereo balance problem
I would replace the output transistors of the bad channel and any very low ohm resistors associated with them.
Whilst youre in there replace the electrolytic caps in the power amp section. Caps are cheap and plentiful.
I dont know what the rest of the circuit looks like but there might be a need to balance the DC offset after replacing transistors.
matelectronics.com and audiolabga.com carry many good replacement transistors.
Dec 30, 2008 | Audio Players & Recorders
Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Oct 10, 2008 | Kenwood Audio Players & Recorders
Nad 310 blows fuse in left channel at turn on.
Hi, Unfortunately, this means that the output transistors on the left channel have blown. I've rebuilt a couple 310s, and I own one myself, so this isn't the first time I've seen it. The chassis doesn't ventilate the left channel as well as it does the right, so it tends to die sooner.
If you can do this yourself, it will not be terribly expensive, but the main output transistor is a MOSFET, which means you'll have to be very careful about static, and you'll have to find a substitute for it as well, as it is no longer available.
I strongly recommend replacing the small electrolytic caps in the amp too. By now heat and age will have taken their toll on them. In my 310, replacing them wasn't an option to get it to behave well.
Aug 20, 2008 | NAD Audio Players & Recorders
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
168 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
