Question about IBM ThinkPad R40 2897 Notebook
R40 think pad laptop fliking
HI
My R40 think pad laptop start flicking and screen black after using 20 minutes if I move, press ******* keyboard just come back screen and I can just shut down if I start again comes same problem after 2 minutes if I wait to half an hour and start I can use again 20 minutes and start same problem. I change heat sink fan but doesn't work please help me.
Thank you
  • mrsanju Jun 21, 2008
    i did every thing is ok but still having same problem screen flicking after 20 minutes.
    Sergeant:
  • 275 Answers
Right click on the desktop and go to the properties option.Click on the Screen Saver Tab and will find Power option . Click on it and check the power schemesr40 think pad laptop  fliking - 6112293.jpg
Posted on Jun 19, 2008
HI, I AM SANDIP FROM CENTRAL ACCOUNTS OF DURGAPUR STEEL PLANT A UNIT OF SAIL having IBM Thinkpad type 2682 ,Product Key GXR3W-GHM34-7RFFM-BVCQJ-WGF4G. PROBLEM- WHEN I AM SWITCHING ON THE POWER A ...
As soon as anything appears on screen after power-on, press F1 (keep clicking it until the BIOS setup screen appears). The first option on the list is Date + Time, click on that, and enter correct date/time. Then press F10 to accept + reboot. If this error happens again, it means that the CMOS battery (which keeps your settings alive) has died; it is cheap + easy to replace, however you have an R40 model, and I avoid working on Rxx series so that job may be harder. I could point you to the R40 service manual, which is very good to dis-assemble that laptop (it is necessary to lift keyboard to get to CMOS battery, which involves removing some screws from the bottom.
May 01, 2017 | IBM ThinkPad R40 2682 Notebook
Samsung r40 shuts down after running for about 20 mins, was told cooling fan was not working so stripped down laptop cleaned fan (was full of dust) reasemmbled and ran all day yesterday, switched on this...
The CPU fan may be faulty and not spinning freely.
If you had removed the heatsink off the CPU did you place new thermal grease/paste on the CPU before installing the heatsink back on the CPU?
Jun 02, 2011 | Samsung R40-K009 R40-K00A R40-K00D"...
Would like to know were the power management chips are located in the IBM r40 think pad computer? The part number number too.
Hi
It's not difficult
You can download the service manual for your laptop, it's .pdf file, and can see all hardware details about your laptop.
Please tell us your results
Good Luck
May 13, 2011 | IBM ThinkPad R40 2722 Notebook
Hi, is there any chance someone could run me through the bois settings in a ibm thinkpad r40 laptop? my screens broke and need to run it through my tv
What on bios is just what you answer yes or no but probably if there is any terminology been used that only where you might be confused but on bios is not compulsory for you to pass through bios you can leave the system and never press the Functional key been ask to press to move to bios settings and if you are tarckle the dates and time then move your arrow keys to the advanced settings from there click on the date is already shown like this 00:00:00 or better still with some kind of old date then on each of the 00: click on your keyboard the - (minus) and + (plus) on the keyboard to adjust the date to the current one ok and then press F10 to save and exit.
Apr 30, 2010 | IBM ThinkPad R40 2722 Notebook
IBM R40 laptop will not start.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 22, 2010 | IBM ThinkPad R40 2722 Notebook
Where is the cmoss battery on think pad r40
You will have to take the palm rest off of the case. The battery, if I recall correctly, is attached to the under side of the palm rest. You MAY be able to get at it if you remove the main battery and look up into the case through the battery compartment.
Mar 13, 2010 | IBM ThinkPad R40 2681
IBM R40 Screen Problems
I think you have an inverter board thats just about dead. It's located in the screens plastic housing at the bottom of the screen just above the keyboard. It's about 4 inches long and a half inch wide.There's just one little cable connecting it. But you have to take your screen apart to get to it. It's easy to replace and relatively inexpensive but it does require a little disassembly skill.
Also ,I will need the exact part number from the bottom of your laptop. There are several different R 40 models, and 2 different screen sizes.
Apr 14, 2009 | IBM 11P836402 for ThinkPad R40 Monitor
Think pad r40/2681(driver prob.i.e. usb/wireless/sound etc.)
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
You need to use a computer that has Internet access to download and transfer the files to your computer.
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Mar 01, 2009 | IBM ThinkPad R40 2681
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2897 Notebook Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
