Question about Datamax DMX E4203 Printer
DATAMAX PRINTER I HAVE DATAMAX PRINTER E-4203 WITH DATATAGGER SOFTWERE BUT PRINTER THROUGH THIS SOFTWERE CANT PRINT ANYTHING
  • Anonymous Mar 29, 2014
    Printing showing error
  • 4 Answers
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
Posted on Jun 19, 2008
Approx. 42 second delay before each print job starts
Make sure you are using the correct and most updated driver.
May 08, 2014 | Datamax E4205A Printer
DATAMAX E-4203 ONLY PRINTING HALF OF THE BARCODE
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Feb 26, 2014 | Datamax DMX E4203 Printer
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Hi! I have a problem with my office Datamax E class printer. When i change tickets in the printer it doesn't print them the right size - normally they are too short. Do you have any idea how to solve...
If you are changing length(feed length) you may have to recalibrate the printer . Also ensure that your print format is the correct length for the stock.
You can look at the setup of the printer using the datamax-oneil printer configutation program, or if it is using IP connection, you can go directly to the internal web page for set up. make the cal length 3 times the label length, or leave at the default value.
Dec 29, 2010 | Datamax E-Class E-4203 Thermal Label...
Our printer is dmx-e-4203. Follow our problem: when we press feed, go out many label and then, when we print, the print is positioning in the middle of two labels. I hope you can help us. Thank you.
IF YOUR PRINTER IS DMX -E-4203 THEN YOU HAVE TO FOLLOW THE CALIBRATION PROCEDURE :(1)TURN OFF THE PRINTER PRESS FEED BUTTON SIMULTENIOUSLY (2) THEN TURN ON THE PRINTER & RELEASE THE FEED BUTTON WHEN PUASE LIGHT GOES OFF.(3)THEN PRESS FEED BUTON YOU WILLGET ONE LIST(4) YOU WILL GET ONE LIST ABOUT ALL THE FUNCTION FIND THE CALIBRATION PROCEDURE IT WILL DO AUTO - CALIBRATION(5) YOU HAVE TO SELECT NO.20OPTION NAMED AS STOP LOCATION SET THAT LOCATION TO COVER POSITION .AFTER ALL THE PROCEDURE WILL HAPPEN JUST TURN OFF THE PRINTER &TURN ON & PLEASE REPLY ME ON MY EMAIL ABOUT THIS
THANKS ®ARDS
VIJAY
Sep 14, 2010 | Datamax DMX E4203 Printer
TRYING TO INSTALL . INSTEAD OF WELCOME TO SEAGULL DRIVER WIZARD MY SCREEN SAYS AUTOPLAY DVD RW DRIVE (D:) DATAMAX
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Aug 31, 2010 | Datamax E-4203 Printer
Only prints ''smeared labels'' with no text even remotely recogniza
You need to alighn your print heads and or buy new ones. Also, the paper must be the right specified paper or it will blotch or smear.
Feb 19, 2009 | Datamax E-Class E-4203 Thermal Label...
Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
May 16, 2008 | Datamax DMX E4203 Printer
Won't print labels
Ended up being the heating settings - they were to low, so when I hit print...it would spit out a label but nothing would be on it.
Problem solved!
May 14, 2008 | Datamax DMX E4203 Printer
Datamax DMX E4203 Printer Logo
590 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
