Question about Envision EN-7220 17" Flat Panel LCD Monitor
Plug and play PL716s proview monitor
After almost two years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off before it finally stays on what can seem to be the problem I trouble shooted the monitor and the results came back as no problem however there is a problem the monitor shouldnt be coming on them blinking off and I shouldnt have to keep turning the power button on and off before it finally stays on can you give me some feedback on what the problem could be
  • Anonymous Jul 04, 2008
    display appears momentarily with a pink tinge then goes blank.
  • Anonymous Aug 04, 2008
    exact same problem
After almost two/ three years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off I cannot keep it on. Please help.
Posted on Nov 16, 2008
I have a Proview PL716S and sometimes the entire
ur monitor got err i need to be changecoz repairing of monitor is unprofit
Apr 14, 2010 | Proview PL916S2 Monitor
ProView PL716s U101 roasted
I would change the caps anyway, they're cheap. The IC's may be running hot trying to make up for the bad caps.
Jan 28, 2009 | Proview Computers & Internet
Power cord for proview monitor model Por PL716S
This link will have it....http://quail.com/index.cfm?gclid=CLuglZORppgCFQu-GgodGwZmoA.RICHARDM69
Jan 23, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Proview monitor PL716s
you ave some blown caps on the vga board replace them and all will be well
Dec 28, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL716s computer monitor
Bad Inverter. Or a surface mount component on the inverter. Either way it needs to be trouble shot down to the component level or replace the inverter board.
Sep 17, 2007 | Gateway FPD2275W LCD Monitor
Proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Aug 16, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Envision EN-7220 17" Flat Panel LCD Monitor Logo
285 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
