Question about Cameras
Somehow my speakers are gone out if i tap thecamera or blow in the speaker part then the sound will come back in
    Scholar:
  • 141 Answers
Hi ladii;
have your camera check, its something inside your camera, loose contact or something.
Posted on Jun 19, 2008
Mixer will only play through one speaker; this is same with organ, microphone and ipod connected. Swopping jacks results in speakers swopping proving that woring is good, but mixer will not play both...
Sounds to me like either an open wire or a blown speaker. I would highly recommend not operating it until it is fixed before you blow the amp. Tapping a 9V battery across the speaker (disconnected from amp) will cause a noise in the speaker, if not it is a broken wire or bad speaker. Good Luck
Jun 06, 2013 | Behringer XENYX X1832 USB Mixer
My 2005 Accord's radio / CD player will not produce sound to the speakers, the display panel works fine. Sometimes a loud static sound will come from the speakers with no volume control, powering off gets...
The sound chip may have gone in the stereo, especially if someone has had it on very loud they sometimes blow, otherwise you have 2 speaker wires touching each other, that way you only get static noise, insidee the door they sometimes come free and touch the body
Check all your speaker wires first.
Jan 17, 2010 | 2005 Honda Accord
Tomtom one 3rd edition, sound not working
My had the same problem after dropped on the stair. I did the reset but no help. Here what I did: uncrewed 4 torx crews and pop out the back cover slowly. remover speaker's wire connector and check speaker resistance 3-4 ohm. reattach connector firmly and did a speaker test in volume preferences menue. Mine works just fine after this attemp. In my case is a loose connection. The battery and speaker can be change as necessary.
Jun 28, 2009 | Tomtom ONE 3rd Edition GPS
Add 2 speakers outside on a 6 speaker surround sound and hear all
You won`t get surround sound mix with 2 speakers, you can have a 2nd zone but this will only play a "Stereo Sound" if you have that playback option with the SC-RT50, what you will need is a speaker selector switch or better known as an A & B switch, this will ideally run from the front left and right speaker output of the receiver into the A & B switch then run into each pair of speakers inside or outside, what is common nowdays are receiver that are known as 2nd zone connections where you can have 2 sets of speaker in different rooms, unfortunatly the SC-PT50 does not have this option.
Feb 03, 2009 | Panasonic SC-RT50 System
SPeaker and Headphone
If both speakers AND headphones aren't working and nothing is muted, it sounds (no pun intended) like your sound card has gone south. Have you checked in Device Manager to see if it's still listed? Right click My Computer>Properties>Hardware>Device Manager. Check under Sound, Video and Game Controllers to see if it's there. If so, right click and choose Update Drivers just in case it somehow got wiped out. That would be the easy fix and I hope it's not your card!
Thanks for using Fixya.com and please rate this tip accordingly.
Oct 18, 2008 | Harman Kardon HK695 Computer Speakers
Ds with no sound
the speakers on your ds could have been blown somehow and that is not fixable unless you open up the ds. try not using any sound for a while and then seeing if the ds uses its speakers. you can try bringing the ds to a gamestop and/or call customer service @ nintendo and they will guide you through the procces.
Oct 15, 2008 | Nintendo DS Console
No sound
playback on the camera? good news is that there really may be nothing wrong with thecamera
this model doesn't have a speaker. but it has a mic so it can record sounds
when you transfer the videos to the computer - it is supposed to play with a sound
Feb 07, 2008 | Kodak EasyShare C513 Digital Camera
Message
Try disconnecting the speaker that you added. If the sound comes back, then you're ok. Just don't add any more speakers. If not, then it's possible the amp is blown.
Too many speakers connected together to one output can cause an overload and either blow a fuse or trigger the protection circuitry. If the protection is triggered or blows a fuse with all speakers disconnected, then your amp is shot.
Hopefully, that's not the case. Try disconnecting all the speakers and see what happens. If you still get the error, then the amp is gone.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Jan 20, 2008 | Audio Players & Recorders
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Is there any way to take these apart?
Is it a powered speaker? If not then if you know how to solder ,sure open her up and move around the wires while shes playing and see if you can duplicate the fault. If you dont know how to solder then take the unit in to be serviced as a loose connection inside a speaker can certainly blow out an amps output circuitry. Good Luck
Jun 25, 2006 | Cambridge Soundworks Center/Surround IV...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
