Question about HP Photosmart 7850 InkJet Printer
Paper feed just goes through will not print - HP Photosmart 7850 InkJet Printer
2 Suggested Answers
asish_shrm
  • 121 Answers
SOURCE: photo paper stops feeding
please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Posted on Nov 10, 2008
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
I have Paper Jam Display on my Canon Super G3 Fax phone L80 FaxScreen.
There is most likely a piece of trapped paper where you cannot see it and it is covering a jam sensor. Try to cheat the machine by turning it off and remove all the printing paper. When you turn it on look down where you see the paper normally feeds and see if you can see any rollers turning. Then, try to take a sheet of paper and feed it through were the printing paper usually goes. Open up the cover where the cartridg goes as well and you may see the trapped paper move when you feed through your piece of paper. Remove the cartridge if necessary to get a good look and see if paper is trapped near.
Jul 08, 2009 | Canon FAXPHONE L80 Laser
HP printer will not feed paper through the rollers
Pick up some Print Roller Cleaner spray, and carefully spray your rollers. As time goes on, fibres from the paper embed in the rollers, which reduce their efficiency to pickup and feed paper. Spray all the rollers and set it dry. You should find that your printer feeds paper. If not, you need a new roller set, available from the HP Spares, or a good local HP Dealer.
Mar 14, 2009 | HP DeskJet 5650 InkJet Printer
No paper feed (brother MCF-440CN)
Had a similar problem with the MFC-885cw. Turns out that , if you have a photo paper tray installed which sits just above the main tray, you need to puill it all the way back towards you otherwise it blocks the paper feed. Not the best design feature I've ever seen.
Feb 20, 2009 | Brother MFC-440CN InkJet Printer
Will not feed paper to print
Do a Mr. clean act on all rollers coming in contact with paper. I use distilled alcohol and cotton and it has worked for me.
Sep 06, 2017 | Dell 1700n Laser Printer
My paper goes to one side when printing starts and it does not print ny work
There may be a scrap of paper stuck in the machine, interfering with normal paper feed. Turn off the printer, and try to force a sheet of paper through the printer by hand. Feed the paper only in the normal direction that the paper goes. Forcing it by hand may push out the stuck scrap. Thin cardstock can be used instead of paper.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
HP Photosmart 7850 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
