Question about Campbell Hausfeld 2 Gallon Air Compressor
I have a 26 gal 5 hp upright campbell hausfield air compress. it will not buildi up air all of a sudden. it is building some as when i pull the pressure relief some air comes out. Any suggestions.
    Genius:
  • 1,274 Answers
Hi, my name is John. Welcome to FixYa. check all your air lines for leaks, check the valve at the bottom of tank, check the line coming form the pump to the tank. You may have to remove it to inspect it. I find this one always is over looked. Thanks for choosing FixYa...John
Posted on Nov 27, 2010
I need to replace the belt on my 5 HP 120 volt 27 gal tank Model WL660001AJ Air compressor. I don't know the part number on the belt, or where to purchase. Can you help?
Hi, my name is John. Welcome to FixYa. Take the belt with you to most any auto parts store and they will match one up for you. Thanks for choosing FixYa...John
Nov 19, 2010 | Campbell Hausfeld 26 - Gallon Air...
What type of oil is needed in my Durabuilt air compressor-6 gallon tank? I need to replace some oil. Thanx. Send response to "gfrommell@wi.rr.com." Thanx.
Howdy. It's actually called Compressor Oil and is available at nearly all hardware stores and tool rental agencies. There are several brands and they are all comparable. I use Senco, but Campbell Hausfield is also good. Farmerbear at FixYa.com
Oct 23, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I bought a HS5180 air compressor from WW Grainger. I lost the manual, and directions to install. Can you please email them to me? Thanks Jeff
Jeff, you can go to the Campbell Hausfield website, and download all of that. You can save it as a PDF file, and just print it yourself.
Apr 08, 2010 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
My campbell hausfield wl660001aj will not come on and I changed the fuse also. 5 gallon vertical
Water is condensed from the compressed air it makes and this can settlel in the switch diaphragm, in cold weather is can freeze and prevent the switch from working.....
Feb 02, 2010 | Campbell Hausfeld Air Tools & Compressors
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Sparking brushes
try blowing out motor i have used a armature cleaner like acetone while motor is unplugged or just replace brushes
Jun 26, 2009 | Coleman Powermate 60 Gallon Air Compressor
Compressor runs hot and won't build pressure
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
Mar 27, 2009 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld 2 Gallon Air Compressor Logo
188 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
