Question about Dishwashers
Candy CDi 454-80 e4 error code, all water seems to be pumped out but pump still running, pump start to run when switching the machine on and e4 appears
3 Suggested Answers
SOURCE: machine not working showing E4 fault
something is stuck in the filter (big olive, valve from baby bottle...) so the water can't get out. Clean filter, then make sure all water is out of the machine (we sucked it out ourselves with a tube and a bucket, ieuw..). Then wait a couple of days: the machine/wires/etc. needs to get dry before you can use it again! Try to turn it on after two or three days. Do not call an expert before you've tried this, it will save you a lot of money... (wish I'd done it...)
Posted on May 27, 2010
SOURCE: Candy CDI 45 E4 code
I have E1 code on Candy dishwasher CDI 45
Posted on Sep 29, 2010
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
What does E4 flashing mean?
E4 means that it is not able to discharge water.
Make sure all water is pumped out of the machine. Switch it off at the wall and unplug. Tilt the machine forward (put a towel down first) all the way till the door is on the floor, and let the rest of the water run out. Return upright.
Hope helps.
Apr 14, 2011 | Candy Dishwashers
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
LX-18 error code E4 what is the problem? Replaced motor runs great.
the water does not seem to be pumping to wash the dishes....could something be plugged? I can hear the pump and it pumps the water out at the end...
Mar 06, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Problem with Candy CDI45, Error E4
The instruction manual defines E4 as "overfilled", a possible reason being too much inlet water. What helped with our machine - removed all dishes inside, then let the machine's pump run briefly to make sure as much water was drained from the system as possible. I then unplugged the device, placed a large towel on the floor around its base, and tilted the machine front-ward, until all water had run out. Lifted the machine back upright, plugged it in, switched on - and voilà! it's working as I speak.
Feb 28, 2008 | Dishwashers
Beumatic
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
Dishwashers Logo
656 people viewed this question
Top Dishwashers Experts
