Question about Water Heaters
Ferroli OPTIMAX HE 31G timer instructions needed at the moment i turn the boiler on and off when needed with the weather coming up isnt ideal it seems quite complex..
Try here..thank the finder
Optimax HE Digital Timer instructions
Posted on Nov 21, 2010
Boiler flame goes on and off
You have a fan or flue issue, is it a ferroli , it could be the venturi in the fan , they get brittle and break, you need a gas safe enginner to sort it out , DO NOT ATTEMPT to do it yourself
Jan 22, 2014 | Water Heaters
Why does my Ferroli HE31C keep switching off code A3.
Here you go, page 30, sounds like it's overheating, possibly a problem with the boiler stat or lack of circulation in the system. http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Apr 06, 2010 | Water Heaters
Dirty injectors on a Saturday morning in an isolated village
WHEN YOU NEED CLEAN I NEJECTER YOU MAY BE CLEANA ONCE DRUM IN WATER+ HCL CIRCULET 15MIN
AFTER CIRCULATE CLEAN WATER
ALSO CIRCULAT WATER+ EDTA+ SMBS POWDER
YOUR INJECTER WILL 80 % PER CLEAN
Mar 06, 2010 | Water Heaters
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
On the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
Jul 23, 2009 | Water Heaters
Missing instructions for setting timer on boiler
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
Feb 21, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Water Heaters Logo
401 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
