Question about Sylvania Televison & Video
When tv is turned on, only half of pic is there (left side)..The right side looks like a bar code, with horz. and vertical lines..There is color behind these lines....After it warms up or a couple hours later the full pic. comes back. TV is 3 years old...Lines being going on for 2 years.
  • Sylvania Master
  • 8,457 Answers
This tv is a standard CRT(tube tv) wright?Yes,than the tv video board have problem with dying capacitors or the main colors decoders IC require resoldering.U have a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders and also understanding basic electronic wright?Take the tv aparts check all those capactors all around the main colors decoders IC for capacitors leakages,replaced all these dying leakages capacitors,will solved this problems.These capacitors alway bulges up or puffing up on it top.That the indication those capacitors are dying and not working to it full capacity.Also resolders the colors decoders IC too.Ur tv problems,will be solved.
Posted on Nov 15, 2010
  • Cameron Guthrie
    Cameron Guthrie Apr 06, 2014
    need more details or link to schematics
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Sony kdl46ex710 half screen 3 colors vertical
This CAN BE a defective panel, but most likely defective capacitors in the power supply section of your TV, and one that requires a good deal of soldering skills not to mention diagnostic ESR meters and capacitance measuring devices to troubleshoot this. Are you sure you're up to this?
Mar 16, 2014 | Televison & Video
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Half my screen works
I had this, and it was just a small connection that was loose.
Dec 22, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Televison & Video Logo
120 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
