Will not turn on, switches itself off straight away
  • alambert3103 Nov 15, 2010
    it now says that it is ''dumping the physical memory disc'' and then switched itself off shortly after.
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Nov 15, 2010
Powered down wont restart
switch off from wall. this is a protection safety thing you need to have it repaired if the power from the wall does not fix it.
Feb 16, 2014 | Yamaha RX-V675
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
My Acer X203HB monitor keeps turing itself off, then turning on and loading for about 5 seconds, then turning off again. it does it randomly and when it chooses! ive tried different screens and they work...
danny_gormle, Hi there. Your lcd display "switch-mode-power-supply" is mostlikely detecting a FAULT with itself or the "cold-cathode-fluorescent-lamp" ballast circuit (called the INVERTER) and is going into what is known as SHUTDOWN mode to try and save itself from having a catastrophic nonrecoverable failure and or FIRE and SMOKE. Get back to me after you visit YOUTUBE and search for video clips of LCD monitor Disassembly and or LCD repair! I'm sure you will find out the most common causes of your type of failure symptom. Your symptom will surely fit into the top 2 at least. After doing the YOUTUBE thing, check with Acer to see if they have a cash+old monitor swapout programme where they send you a REFURBISHED unit in return. It's that or have it refurbished locally or do repair yourself. With the words 'straight away' I suspect your from England, Canada, or The Land Down Under? I'm louie12fix on fixya or lmistyrel @ aol.com north of Chicago. Hope this helps you out a bit. please rate this response on fixya. Bye for now.
Oct 07, 2009 | Acer Computers & Internet
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Kodak easyshare c613
you need to clean your lens with a tissue sort of cloth, DO NOT GET IT WET! that will ruin your camera.
Jun 10, 2008 | Kodak EasyShare C613 Digital Camera
Light turns off
Wiring is faulty (probably in fan unit itself), have it checked straight away.
Jul 15, 2007 | Hampton Bay 73554 Antigua Ceiling Fan
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
Computers & Internet Logo
David Payne
David Payne
