The high pressure hose has been cut. is there anyway to safely join together. IT is a 2400 psi high press water hose
  • 487 Answers
There are hose kits to join the hose together. Do not try it with just a clamp as it might result in injurie. I am guessing you are not talking about a washing machine but pressure washer. A new pressure hose is not to expensive. You can get them for every brand
Posted on Jun 19, 2008
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
Honda pressure washer 2400 psi worked fine yesterday, today the pressure is low, seems to work fine except the level of press sure is low any suggestions?
Check for an inline filter on the water hose connection, the low pressure side. Depending on your water quality and if any spiders made homes inside your hose, they can get clogged pretty easily.
Jun 07, 2011 | Garden
No Pressure
Here are some possible problems and solutions:
  1. Insufficient water suppy. Make sure your using a 3/4" diameter hose, The more length of hose the less water pressure you have so keep the supply hose as short as possible.
  2. Plugged Pump Inlet Filter. Check and Clean.
  3. Wrong Nozzle. Make sure you have a high pressure nozzle installed on the wand.
  4. Plugged Nozzle, inspect and clean.
  5. Worn Nozzle, inspect and replace.
  6. Leak in pressure hose, inspect for damages and replace if any.
I Hope This has helped, please rate the answer if it has been helpful. Good Luck and have a great weekend.
Apr 03, 2010 | Plumbing
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Hi, My question involves a:Honda GCV160 5.5Chore Master 2400 psi Model CV-2400=4MHC I have very little use on it. I broke the sprayer hose on it the other day and ordered a new one for this model. I...
  1. put in your garden hose
  2. turn on the water
  3. leave it to run for one min.
  4. kink the garden hoes
  5. connect the hi pressure hose "the one you ordered"
pull the trigger then start
if this don't work start the machine without the hi pressure hose.
no pressure machine needs valves.
Jul 31, 2009 | Garden
My high pressure 2400 psi hose blew out.
Hi cwsales:
Sorry, the pressure will be too much for a your mend to work. You will just get wet. A professional hose repair shop is your best bet, or a new hose.
Jul 14, 2009 | Campbell Hausfeld Garden
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
