Question about Vacuums
Lower handle pole will not stay in. It appears to have lost spring loaded lock.
  • 2,299 Answers
Yes. They do have a spring loaded lock. More than likely this lock has broke and have lost the part. Let me know what kind of vacuum it is, and I will see if I can find you a replacement part. I will need to know the band and model. Thanks!
Posted on Nov 15, 2010
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
Jan 10, 2017 | Dyson Vacuums
Dyson DC28 handle will not go down
Hi David,
I am sorry to hear you are having difficulty reclining your machine. Based on the description you provided, we may be able to help you resolve this right over the phone. Please call us at 1-866-693-9766 (US) or 0800 298 0298 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Jul 01, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
The brush does not move when turned on. The model number is UH70015. The belt appears loose.
There are two belts on this machine. The belt on the brush roller will appear loose when in upright locked position. Releasing the handle to an in use position releases a spring loaded idler pulley which increases tension on the brush roll driving belt. Check whether pwr on/off button flashes when attempting to turn on. This may indicate an obstruction or faulty sensor.
Feb 22, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
Regarding my Kirby Generation 3 upright vacuum cleaner: the handle does not lock into place, but rather falls to the floor. Any thoughts on how to get it to stay in place? Also, I lost my owner/operator...
The plate that catches the handle to lock has a hidden spring behind that plate.I would leave it alone for the unit is pressed together. Used ones are found most everyday on Ebay. The owners manual maybe found on this website
freemanuals.com
Mar 26, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Vacuum will not pick up dirt. plate in hose stays shut. It has a spring that goes to the plate assemily but will not open. What make it open and close. U6616-900 Hoover Vac Alex
Sounds like you have a valve arm not operating properly. The valve door sould spring open when you lower the handle and will shut when the handle is raised and pushes down on the rear valve arm. See a parts diagram and look at parts 39-41 and 19.
Feb 09, 2010 | Hoover U6616-900 WindTunnel Bagless...
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Reassemble of handle on upright
place handle half with the posts that hold the screws facing up.
silver pole with hole that goes completely throuigh goes over lower screw post (Long side)
static wire - L shaped end goes in small hole on opposite side of handle just below
vacuum switch hole, curve of wire should follow curve of handle and fits into top of
silver pole and pushes againt it providing push to hold siver pole.
hope this helps
Apr 02, 2008 | Oreck XL2200 Bagged Upright Vacuum
Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Oct 01, 2007 | Vacuums
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
