Question about LG Washing Machines
Turn off Beep sounds LG Front Loader WD1238C
Hi, I would dearly love to turn of the shrill sounding beeps that this machine makes when power up and selecting wash options. It is really very loud and piercing. Can anyone help? Cheers
SOURCE: beep coming from washing machine
You might have the end of cycle setting turned on. It will beep to let you know that the washer is done. Can turn off, under options on the control panel.
Posted on Oct 19, 2008
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
  • 343 Answers
SOURCE: Fisher and paykel GW611 excellence top loader wont
Check Out Of Balance switch This will prevent spinning and programme from advancing
Posted on Apr 18, 2010
  • 112 Answers
SOURCE: Wash & Rinse continuouslly gives beep sound
Can you give me model number?
What cycle are you trying to run that give you the continuous beep. It could be that it thinks the washer's door is not shut.
Posted on May 03, 2010
My LG Wd1238c front loader machine wont turn on, plugged in but nothing even turns on..
You have a dead control board that will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 28, 2012 | LG WM-2277HW Front Load Washer
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
WHEN I PUSH THE BUTTON TO TURN ON THE COMPUTER ALL THAT HAPPENS IS A RED LIGHT COMES ON AND A BEEPING SOUND
hi
the length of the beep and the number of beeps you get when turning on your PC, indiactes a memory or power supply issue.
what is the model of the computer ?
go to this link and read carefully -- it will help you resolve the issue
http://www.computerhope.com/beep.htm
i will await your reply with model of computer and maker of it . let me know the # of beeps and length (short or long beep)
Dec 13, 2010 | Computers & Internet
Making beeping sound when i start up the computer
A beep sound can be due to memory problem.
First use the following steps:
1 Turn off the system and disconnect power cables
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If you still get a continuous beep sound, the next step will be to re-seat memory modules (after turning off the system).
Mar 08, 2010 | E-Machines eMachines Desktop PC
Beep coming from washing machine
Oct 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
MY L.G TV IS NOT WORKING
try turning it on by the power after you pull the plug and put it back in. press the channell up button to see if it will turn n, if it still makes this sound locate the personyou bought it from and let them know. hope you sill have warranty.
Jul 15, 2008 | Televison & Video
Error Code t
In my LG manual "t" does not say what the problem is but the solution says "unplug the power and call for service"
Jan 13, 2008 | LG WD-1295FB Front Load Washer
Washing Machines Logo
991 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
