Question about Konka KDL32AT23U 32 in. LCD Television
I need just to set my TV for PAL-M.
Hi there! I just moved to Brazil and I need to set my TV for PAL-M. Is it possible to do from the factory menu control? How?
  • 426 Answers
No i dont think it is possible, however when you are in your menu go to inputs and select the format , then see if it will let you
Posted on Jun 19, 2008
  • Lee N.
    Lee N. Jun 19, 2008
    if your tv doesnt support this running it through a vcr should do the trick :)
How do i change my channel tuner from NTSC to PAL?
you need to get a converter that takes pal and converts it to ntsc.
Apr 16, 2012 | Sanyo DP50747 50 in. Plasma TV
No color TV on my Trutech 7'' LCD TV + DVD under the cabinet model KLV3170
The TV broadcast system in Brazil is PAL-M.
If this TV was bought from the US then the TV will be expecting the NTSC system.
Your other American TV may be a multi standard TV and is able to detect and adapt to your PAL broadcast system. Not all TVs do this.
How do you connect the DVD to the Trutech TV? Is it with a Scart connector? If so then the TV will not be using any broadcast standard at all and that is why it works properly.
Unfortunately if you have searched all the menus and manual instructions without finding a TV system selection, then this TV may never be able to receive TV broadcast in colour.
Nov 24, 2007 | Televison & Video
Hello, i just bought an lcd Tv converter made by manhattan. the model is 176156. the problem is in the video section, don't let me change the standards (NTSC, PAL, PAL-NC, etc) want to know if there
I think you press the wrong button that change the settings of your TV to restore it original settings kindly go to menu and find factory settings then press enter..
hope it helps..
Dec 11, 2011 | Manhattan LCD TV Converter/Tuner (176156)...
No sound on certain channels on Panasonic 32" LCD TV
Please open the AUDIO settings and check the AUDIO frequency set on the chosen channel.
Make sure it corresponds the frequecy in your transmission.
It can be 4.5, 5.5 or 6 if PAL is the colour system . ( being PALB/G, I or M)
Select accordingly and set.
PAL broadcast systems
Jul 29, 2011 | Televison & Video
Does Sharp LC-42SB48UT TV support PAL ? if anyone has this TV you can search under the Option Menu to "Select the video signal system compatible with your equipment from the list...
PAL-M is 525 line 29.97 frames per sec, PAL-N is 625 line 50 frames per sec. Most countries (e.g. UK) use PAL B/G/D/K/I which is 625 line 25 frames per sec. PAl-M is used in Brazil, PAL-N is used in Uraguay and Paraguay. Most modern TVs will handle both PAL and NTSC as long as the RGB input is used (via scart or HDMI).
Mar 08, 2011 | Sharp LC32SB28UT 32 in. HDTV LCD
I´m in Brazil.My son gives me this Tv comes from Mexico. Here in Brazil the transmission is in PAL-M and this Tv is NTSC. How I do to transformer to PAL-M?
U can't sorry.PAL or NTSC are build into the circuit boards itself.Sent the tv back to ur son,u can't do it.
Oct 21, 2010 | GE 27GT277 27" TV
you can use the factorial reset,,,,,,,,from factorial menu,,,,,,,which provide a different internal settings,,,,,,,,this will adjust all the setting as ideal,,,,,,,modified
Jun 19, 2009 | Samsung DLP HL-P5663W 56" TV
My tv doest work properly em Brazil
HI,
I'll think youve got a different PAL system in Brazil.
Brazil has PAL-M en RSA PAL.
regards,
Gerard
Oct 30, 2008 | Hisense TA42P40M 42 in. Plasma Television
Taking TV from UK to Australia
The TV has a setting for Australia in the Digital setup menu, so there shouldn't be a problem.
The mains voltage in Australia is 240V - 50Hz, so you should only need to change the mains lead.
If you decide to go ahead, when you set up the tv:
Switch on tv.
Press and hold "MENU" on the side of the tv.
Menu will appear on-screen.
Continue to hold until menu clears.
Wait.
TV will reset to factory settings, allowing you to re-tune the tv.
Jan 08, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
TV SANYO MODEL DS 25390
It would be a waste to take this TV to Brazil, as this is not a Multi system TV, and will not recieve PAL M broadcasts.
May 29, 2007 | Sanyo DS25390 TV
Konka KDL32AT23U 32 in. LCD Television Logo
51 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
