Question about Bose LIFESTYLE 28 Series III System
Subwoofer wont come on - Bose LIFESTYLE 28 Series III System
Subwoofer
did you wire the amps in your car? or is it a stock amp?
Dec 17, 2013 | Car Audio & Video
12in rockfordfosgates wont play bass
is it the proper amp it must be class D amp or bridgeable 2 or 4 channel. how do you have it hooked up?
Jun 12, 2012 | Rockford Fosgate RFP3212 Car Subwoofer
Its blown, wondering if there is a way to repair it.
call kenwood customer support and find out if they or someone else makes a recone kit for it. If its one of there top of the line subwoofers they probably will. If its just one of their entry line subwoofers im willing to bet that they wont.
Aug 07, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Cant seem to find fuses that wont blow for my 10' re series speakers
if a fuse does not blow when a short is present then the wire or unit will catch fire. You have a dead short most likley in the subwoofer. If you unplug the subwoofer and the fuse does not blow then your unit failed.
May 27, 2010 | Cerwin Vega LW10 Subwoofer
Subwoofer wont work
on the back of your pioneer audio/video receiver, you will plug the cable into the subwoofer pre out (back of your receiver) then connect this same cable to your subwoofer.
Feb 05, 2010 | Pioneer VSX-D509S Receiver
They just turn off and wont work anymore
if the amp does not turn on then try to move the ground to a better spot
Nov 26, 2009 | Car Audio & Video
My dual subs wont light up and my ndual tweeters wont either
check the wire connection with the lights then bulbs okay then look on the inside of the box for an extra wire for power for the lights if that dosent work
Feb 02, 2009 | Dual XNBP12D Car Subwoofer
Amp and cap wont turn on
check fuses on AMP , fuse from battery under hood , .It should not be farther than 18 inches from battery meaning the fuse..
Dec 06, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My speaker wont put out sound
The voice coil is blown off the cone. It's a goner.
Sep 03, 2007 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Bose LIFESTYLE 28 Series III System Logo
42 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
