Question about Muratec F-300 Fax
The machine "Alarm" keys going off and the message
  • abp20 Nov 15, 2010
    The machine will either say "Call for Service" or "Please call Service"...you have to be precise as they mean different things.
  • abp20 Nov 16, 2010
    The machine will say "CALL FOR SERVICE" or "PLEASE CALL SERVICE".....these mean 2 different things so you will have to be precise.
    Genius:
  • 1,218 Answers
The machine will say "call service" OR "Please call service"... they mean 2 different things...you will have to be precise.
Posted on Nov 19, 2010
Machine will not sew. Message comes on screen, "Put on Foot A."
the machine probably need to be serviced to see if the motherboard
has a problem
Jan 07, 2013 | Sewing Machines
Tip
Sharp AL2020 AL2040 AL2060 AL2080 H4 H-4 code reset procedure
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:<br /> Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys) <br />Press "C" then the "Auto" key (exposure mode) then the "C" key then the "Auto" key again.<br />So in other words C, Auto, C, Auto<br />If done correctly the display should go blank.<br />Then key in 14 as if you were going to make 14 copies.<br />Now press the "print" button<br />The machine should automatically shut down and restart with the H4 code being gone.<br /> If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced. <br /> Works on Sharp AL series 2020 2040 2060 and 2080<br /> Good Luck and Thank You for using Fixya.<br />
on Dec 22, 2010 | Office Equipment & Supplies
Our Sharp ARM455N Copier shows "Maintenance
this is message that the copier did certain amount of copies and it needs to be cleaned and ispected. The purpose of preventive maintenace is to stop or reduce problems before they occure. In most cases they occure when you need the copier urgently.
This can be reseted in simulation mode, but I recommend to get service technician to service the copier.
If you want to reset the alarm leave the email and I'll send you the service manual.
Sep 09, 2011 | Sharp AR-M455N Copier
The vehicle was hit by lightning today and now I have a message on the dash that says "service RSC now" and an audible alarm that sounds at the same time. After 20-30 seconds the message goes...
Hello, did it make you hair stand on it ends. You vehicle needs to be serviced at the dealership.
All the computer controls need to be reset. Inside an automobile is the safest place to be when lightning strikes. I hope this help you. GB...stewbison
Aug 23, 2011 | 2008 Ford Explorer
"wrong cartridge" message appears, new
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
I found a reset sequence for a MP730 printer in this website that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 or F50 printers.
Feb 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
6160 key pad "open circuit"
open ckt on the keypad refers to the data lines going to the keypad. check to make sure the yellow and green wires from keypad are properly connected.
Feb 17, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
I've had my Lexmark x2580 installed on my new Acer Windows 7 machine for 6 months now. I kept getting a "please register" message but since it is about 2 yrs old & I'd already registered, I...
Make sure your print spooler service is running. This article in the Lexmark website about How to Restart or Reset the Print Spooler in Windows might help you enable the service again. If problem continues, please contact Lexmark technical support for additional assistance.
Feb 10, 2011 | Lexmark X2500 All-In-One Printer
Canon Multipass 730 Alarm light blinking and "PLEASE WAIT" on the screen. It is making a sound like it is about to print or copy something, it is an intermittent running. I tried shutting down...
Hello Mary, You can reset the Machine;
Service Centers near your area; Click Here, and Enter your Zip Code on the target page.
Nov 18, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
I can't get my sunroof to close. my message board
Most likely the alarm siren module has failed. The alarm module is wired in series with the sunroof module. If the alarm siren fails (and it does) it will take the sunroof module offline with it.
What I would do is to unplug the module and cycle the key. If it is the siren module the sunroof will work. If it still doesn't work then it could be a wiring problem and would need to be taken to a trusted shop for repairs.
Here is a link to a website that will show detailed instructions on how to remove the alarm module.
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=11&t=17479
After the module is disconnected you may need to reinitilize the UEM. Get in the car and shut the door.
For most you can turn the key on and off, then lock and unlock the car with the remote.
For others just lock and unlock the car three times.
I hope this helps.
Mar 06, 2009 | 2004 Volvo S60
Muratec F-300 Fax Logo
151 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
