Question about Compaq Computers & Internet
I have a compaq laptop and it turns on but the screen is black and it doesnt want to charge and i have plugged it in in diffrent electrical outlets and it still doesnt work what can i do?
  • 558 Answers
This motherboard or charging circuit in the laptop has been damaged, with the video problem I would go with a motherboard that is fried, so either replace the motherboard or charging circuit board or buy a new laptop
Posted on Jun 19, 2008
I turned my PC off and it never came back on, screen is black, any ideas?
Check all connections. Unplug them and plug them back in to make sure they are making connection. Some screens will have two cords plus plug it into electric outlet.
If your computer is running look for a switch on the monitor to turn it on.
Jun 08, 2015 | HP Pavilion All-in-One MS225
I have a compaq presario sr 1000. The computer turn on fans running no beeps but I get a black screen it will liad to the compaq screen a d then goes black can use f1,f2,esc,f8 but the. Other keys cant use...
your hard drive is most likely dead for an old laptop it will be anywhere from 100 - 300$. this is most likley beaucse a hardrive on a computer that old will usually be the first thing to fail. in my opnion you should just buy a new laptop because you are bound to have more issues in the near futre with this computer.
Apr 30, 2014 | Computers & Internet
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
HP Compaq NC8430: Laptop does not want to charge battery
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Jan 30, 2013 | HP Compaq nc8430 Notebook
Laptop doesnot start, starting problem, compaq pressario V6000, purchased in 2007
If your laptop won't power on or stay on for long then follow these quick and easy steps to troubleshoot the problem.
  1. Ensure your battery is holding a charge. Some laptops will automatically shut-off if the battery won't hold a charge. In that case, replace your battery with a new one and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
  2. Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. You will need to replace it. Note: High heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (burning hot when you touch it), then this is not good.
  3. Check your power cord. Are there any nicks, cuts or kinks? If so, unplug it from the AC power and repair with electrical tape or better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap and could save you from electrical shock.
  4. Check your laptop lid switch. If it is broken or not lit, you may have power but your screen may not come on. This is usually a little button located close to the lid hinge that turns on or off your screen when your lid is open or closed respectively. Normally the operator does not push this button. These are fragile and broken easily on some laptop models. Sometimes these can be repaired, more often they will require replacements. If you aren't an expert repair person, get a technician to repair or replace it for you.
  5. If you have tried these easy solutions and it still won't power on, then your problem lies elsewhere. You may have an internal power switch or voltage regulator problem. Internal problems will require professional help so go on down to your local PC store and have a qualified technican take a look.
Mar 03, 2011 | HP Compaq Presario V6000 Motherboard -...
I have an compaq presariov2000 laptop. the problem is battery not charging and the charging symbol is also in a hide and seek mood. I also try scan for hardware changes method but it won't work. plz help.
go to compaq's website, download the latest Bios Update, run the bios update while the power suply is connected on the laptop. after the update, the power adapter should be recognized by the laptop
Sep 07, 2010 | HP Compaq Presario V2000 Notebook
I turned on my laptop the lights came on heard the fan breifly. The screen stayed black and never turned on. The laptop just kept turn off and on every few seconds. It is plugged into the outlet. What is...
has it been recently attached to a docking station, or a external monitor?
I do not have a Presario Compaq handy, but on my Dell, the key combination to change monitor outputs is Fn + F8.
If you can see which of your keys on your laptop keyboard switches the video output perhaps that might bring it to life.
but it might be more than that. is it that the computer is dead? no beeps, fans or activity? , or does it have all that, but no screen output?
try plugging in an external screen if you have the opportunity, and see if it shows anything.
Jul 10, 2010 | Compaq Presario Notebook
Computer is plugged in, but won't turn on
HI,
POWER ON POWER DOWN PROBLEM,ITS DUE TO AC TO DC INVERTER CIRCUIT IN RIGHT SIDE, INSIDE OF LAPTOP,IT IS SHORTED,APPROACH LAPTOP CHIPLEVEL LEVEL LAB FOR REPAIR.
TNKS
RABBANEES
Nov 04, 2009 | HP Compaq Presario F756NR Notebook
My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Aug 16, 2009 | HP Compaq Presario CQ60-249US Notebook
Computers & Internet Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
