Question about Poulan P4018WT Wild Thing 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw
Need to replace all gas lines - Poulan P4018WT Wild Thing 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
  1. Empty the fuel tank on the chainsaw of any remaining fuel. Pull the cap from the tank and turn the unit upside down. Drain the fuel into an approved fuel container. If the fuel is old (more than about a year) dispose of it according to local regulations for hazardous materials. (It can be kept longer by adding a fuel stabilizer.)
  2. Pull the fuel line where it attaches to the carburetor using the end of the needle-nose pliers. The old fuel line may take some force to pull free from the metal tube.
  3. Push on the fuel line to feed it into the fuel tank. Hold the chain saw upside down. Shake the unit to get the fuel filter into the opening of the tank. Pull the filter free of the tank. Feed the remaining fuel line through the access hole at the bottom of the tank. Dispose of the filter and old fuel line in accordance with disposal regulations.
  4. Feed one end of the new fuel line into and through the bottom access hole of the fuel tank. Push approximately 6 to 8 inches into the tank. You can pull back any excess line later. Grab the end of the plastic line with the needle-nose pliers. Bring the line through the gas tank fill opening.
  5. Attach the new filter to the end of the new fuel line. Feed the filter back into the fuel tank. Pull any excess line from the tank. You will want approximately 3 to 4 inches of fuel line inside the tank.
  6. Route the new fuel line to the carburetor. Cut the line to length with the cutters on the needle-nose pliers. Attach the line to the metal tube.
  7. Fill the fuel tank with fresh gas-oil fuel for 2-stroke engines and start the chainsaw. It may take a few pulls to prime the new line with fuel.
  8. Some models come with a priming bulb. Make sure you press the priming bulb three to four times before trying to start. This will prime the gas lines and remove any excess air trapped in the lines.
Posted on Nov 15, 2010
Gas line disconnected from fuel block
Yes, the gas line connector needs to be replaced. This is probably why it came disconnected.
Aug 30, 2012 | 2000 Volkswagen Golf
25cc Gas Line Trimmer- both gas lines have disolved and the fuel filter is just rolling around inside the tank. I have replacement fuel line. Do I need to replace the fuel filter?
It is never a bad idea to do so. If the unit has some years on it, I would say yes. Inspect it, and if it is still nice and white, keep it. If it isn't, I would replace it.
Aug 14, 2011 | Craftsman 25cc Gas Line Trimmer
Need to know where the termostat goes in the waterheter?
The thermostat probe on most residential water heaters is part of the gas valve. The thermostat is a non replaceable part of the gas vale and if your t-stat is bad you will need to replace the gas valve also.
This is generally not a very hard job just start off by shutting gas supply valve to off position.Disconnect main gas line to burner,line to pilot light, and thermocouple from gas valve. Remove pipe fitting from gas valve and use large pipe wrench to loosen gas valve.
Before you loosen gas valve you will need to shut water supply off and drain water from tank.MOST WATER HEATER GAS VALVES ARE PRETTY STANDARD ITEMS AVAILABLE AT MOST HARDWARE STORES. Just make sure you purchase valve for the type of fuel you have,such as l.p. or natural gas.Remove gas valve by turning counterclockwise. Use teflon tape or pipe joint compound on all threaded connections for reassembly. Hook up gas line,burner supply line,pilot and thermocouple lines. Refill tank and check and check for leaks. Light pilot and turn gas control to on. Set to desired heat setting . Also check all gas fitting for leaks. Good luck. Thanks
Dec 17, 2010 | Water Heaters
I have a 25cc gas trimmer. It leaks a little gas from the clear, flexible gas supply line(s). Is it possible (practical ?) to repair a leak in the gas line(s) ? Can the lines be replaced...
They get replaced all the time. The "new" gas with ethanol tends to deteriorate them more quickly nowadays. Small engine repair shop has the fuel lines you need. Repairing them is not done.
If you have the Craftsman trimmer, just ask for about a foot or two of each of the 2 different size lines. They are called "Tygon" fuel lines. Runs about a dollar/foot for the stuff.
Nov 12, 2010 | Craftsman Garden
I have a weed Eder 50 gas line i need to replace but i have to
There are two connections on the carburetor. One is the inlet and the other is a return, Check closely.
Apr 23, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Need diagram of gas lines for a 1998 oldsmobil bravado can you tell me how to replace the gas line to the gas tank of a 1998 oldsmobile bravoda?
Gas tank drop to replace rear lines. Pretty major job all around. If you want a good deal on used lines sets look at ebay "stores" for "s10warehouse". He has several good used line sets cheap.
Feb 12, 2010 | 1998 Oldsmobile Bravada
Some one played a bad joke on me they put antifrezee in my gas tank and what to do to get out
Take to a garage and you will soon find out that "bad joke" is the wrong name for this. All gas must be removed and gas tank dropped and cleaned. you can only hope that that will fix it. Fuel pump, line and injectors may also need attention.
Nov 15, 2009 | 1996 Ford Taurus
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
How to replace a fuel line
No biggy, you need to buy the same size fuel line tubing, preferably from the dealer, and replace it by undoing the tubing fasteners, little clips you undo with a pair of pliers. Before doing this, make sure you cut off the fuel line valve which should be right under the gas tank, if none, empty the gas tank in a seperate container. Good luck.
May 31, 2009 | Garden
Poulan P4018WT Wild Thing 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw Logo
310 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
