Question about Eddie Bauer Musical Rocking Bassinet 10330WOW Crib
Bedding Is it OK to wash ALL of the bedding? The canopy part has that stiff piece in it, and I was wondering how it would hold up in the washing machine. Thanks
    Problem Solver:
  • 5 Answers
I got this bassinet 2nd hand. I can tell you that I did wash the whole set. You have to take the screws out at either end to remove the cover (one screw is behind the batteries in the music box). I removed the plastic parts (the slits are closed with velcro for the flat plastic panels so the plastic simply slides out). The hoops were a little more difficult but since it is an overlap closing and the hoops are flexible, you can remove them. Simply wash in cold water and hang to dry. When its dry, you can put the plastic slides and hoops back in the same way you took them out. Came out fine.
Posted on Sep 01, 2008
I had the same problem. I bought the bassinet second hand, assembled. I couldn't figure out how to remove the bedding. It seems like a lot of work to have to unscrew every time it needs changing. !!!
Posted on Oct 20, 2008
I have the same problem. I wish I could just replace it but you cant by it seperately.....
Posted on Aug 05, 2008
3 Suggested Answers
pauman
  • 248 Answers
SOURCE: Washing the bedding
no. wash the canopy manually.. soak it in soap and water then rinse.
Posted on Jun 20, 2008
I HAVE JUST WASHED THE LINER WITH THE STIFF PIECE IN IT ON COLD WATER AND DELICATE IN THE WASHING MACHINE. IT CAME OUT FINE. JUST HAVE TO LET HANG DRY. GOOD AS NEW!
Posted on Jul 25, 2008
Simson top loader washing machine drum does not spin
Your motor coupling must be worn off. Replace it. It is centered with motor and transmation 2 small plastic pieces
don't wash bed blankets. Or carpets or alike. This is the major problem
Feb 16, 2015 | Washing Machines
What is the difference between a canopy bed and a four poster bed?
A canopy bed is decorative and has 4 posts connecting with fabric hanging from them.7_18_2012_2_55_42_pm.jpg
May 30, 2012 | Furniture
I can't remove the canopy on my graco snug ride car seat to wash it. I'm having trouble separating the two parts to get the material off.
The two plastic pieces clip together inside the fabric of the canopy, but if you push the fabric all the way to one side, you can expose the latch where the two pieces meet. The two pieces are identical, so you can push in on the tab on either piece to separate them. You have to push firmly, but they should separate easily.
Once you've washed the canopy, just thread one of the plastic pieces through the canopy and snap the two back together by sliding them together.
Hope that helps!
Aug 20, 2010 | Graco Snugride
I need assembly instructions for disney princess
Use the hardware that comes with the Disney Princess canopy package to install the main canopy hook in your ceiling. Center the steel ceiling hook above the center of the twin bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions and insert the four poles into the sleeves of the canopy. The two longer poles will run lengthwise above the bed, while the two shorter pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling hook by slipping the plastic ring of the canopy onto the hook. The four polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
  • Jul 10, 2010 | Princess International Nursery Crib Bed...
    My Whirlpool Cabrio top load washer won't start now but it first started by giving LD code when would wash only heavy items like full load of towels or bedding (all others ok). If I let it sit for awhile...
    we ran into this problem with ours too. I swear, this washing machine is the biggest piece of junk I've ever bought.
    We used to get the LD code at the beginning of each load of wash. We solved this by manually holding the lid down tight until the lock mechanism clicked in place. Once locked, it should stay that way for the duration of the wash cycle.
    One day, it just stopped giving us locking problems.
    Sep 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    I need the instructions for the cosco heritage collection crib model number da0504kmc1w
    This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
    www.milliondollarbaby.com/help.milliondollarbaby.com/
    *For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
    *For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
    For cribs with Safety Glide nylon(rodless) hardware
    Sleigh Convertible 3001 Crib
    Sleigh Convertible 3091 Crib - Safety Glide
    Jenny Lind Crib
    Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
    Ashley/Alexandria Crib (3-piece headboard) +Day bed info
    Lauren Crib ) +Day bed info
    Emily Crib (One piece headboard) ) +Day bed info
    Emily Crib (Four-piece headboard) ) +Day bed info
    Mini Emily Crib
    Anastasia Crib
    Bridget Crib
    Valerie Crib ) +Day bed info
    Bailey Crib ) +Day bed info
    Ellie Crib Day bed and full bed info
    Kalani Crib Day bed and full bed info
    Bordeaux Crib Day bed and full bed info
    Annabelle Mini Crib
    Italian Cribs-Metal Barrel Nut
    Italian Cribs-Nylon Nut
    Canopy cribs with snap-in spring hanger hardware
    Canopy cribs with metal bolt-in hardware
    May 17, 2009 | Baby Gear
    Need instructions ofr converting crib to a toddler bed.
    Jenny Lind Crib
    Mini Emily Crib
    Anastasia Crib
    Bridget Crib
    Annabelle Mini Crib
    May 16, 2009 | Bassett New Haven 3 N 1 Crib
    Assembling Instructions model 01720-1
    Jenny Lind Crib
    Mini Emily Crib
    Anastasia Crib
    Bridget Crib
    Annabelle Mini Crib
    Dec 13, 2008 | Simmons Mattress Matino - Natural Maple...
    Washing the bedding
    Jun 18, 2008 | Eddie Bauer Musical Rocking Bassinet...
    Removing Canopy
    I don't know what brand you have, but if you look on the inside of the holders for the canopy, there should be a little plastic tab holding the hooked end of the canopy frame in place.  Use a small screwdriver to lift the tab up enough so you can slide the hook out.  Once you have it out, remove the canopy and wash away.
    Oct 11, 2007 | Evenflo Cozy Carry 5
    Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Logo
    715 people viewed this question
    Top Eddie Bauer Baby Gear Experts
    Jennifer Rock
    Jennifer Rock
    Nikki  Mclean
    Nikki Mclean
    woodzowl307
    Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
