Question about Brother GX-6750 Typewriter
How do I get to the ribbon to change it? and then how do I change it ? Thanks
  • 398 Answers
You change the Cassette that holds the ribbon.How do I get to - radarron_3.gif
Posted on Dec 06, 2010
My DFX 8000 Printer head is moving, but it is not printing, ribbon and head is OK. i change the head and ribbon but problem is same.
Thanks, I Try it. but it is still not printing, because printer head pins
are not coming to the paper. Head pins printing sound is coming.
thanks
Aug 13, 2013 | Epson DFX 8000 Matrix Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
HOW DO I CHANGE THE RIBBON?
You can use the below link that will take you to the brother FAQ website. Follow the FAQ to change the ribbon.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000500/000045/faq000545_001.html?reg=us&c=ca&lang=en&prod=fax575_us&Cat=7
Thanks,
Pat
May 13, 2010 | Brother FAX-575 Plain Paper Thermal
Changed ribbon and now the letters are all messed up
The ribbon or L/O tape are probably tangled in trhe P/W, REmove them turn the T/W off and on then try again, if you still have trouble check for bent spokes on the P/W.
DickyO
May 11, 2009 | Office Equipment & Supplies
TLP2844 won't print anything after changing ribbon
Are you using Zebra original ribbon? Remove the ribbon and rub it hard on a piece of paper from both sides. The side that marks the paper is the side that has to face down on the printer. If you still have problems, get back to me. I would also check the darkness mainly if the ribbon is not genuine Zebra as different ribbons have different fusion points. It would also help if you can give me the code or part number of the ribbon you are using.
Apr 01, 2009 | Zebra LP 2844 Thermal Printer
Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Dec 15, 2008 | Sony UPDR150 Thermal Photo Printer
Diagram to change ribbon cartridge
The cartridge just snaps on, printing half letters may be caused by the ribbon being folded over on itself or not moving look at the ribbon toward a light you should see each letter clearly thru the ribbon
Sep 20, 2008 | Swintec 7040 Typewriter
Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
May 22, 2008 | Brother Office Equipment & Supplies
Fuji finepic F470 - Damage Ribbon cable for menu controls
Broken ribbon cable cause key pad not functioning, you may need contact and order a key unit from fujifilm spare parts and replace it to solve  the problem.
Mar 29, 2008 | Fuji FinePix F470 Digital Camera
Omar
its ribbon has damaged, ribbon which connects upper part with lower part.thats why ur screen goes black. take it to technician once ribbon is changed, ur phone will start working like new one. thanks
Feb 28, 2008 | Nokia 6288 Cellular Phone
Brother GX-6750 Typewriter Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
