Careful cleaning of the VCR tape head with alcohol and a soft cloth (q-tips sometimes leave fuzz behind) may help, but you could have a problem in the circuit that switches from VCR to Tuner.
Well I think that the the machines mechanical piece that allows you to record is broken then and needs to be fixed so we perfer DVD players and dvd disc;s instead they are better at recording and have less problems too.
1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
(*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
You should be seeing the DVD in your TV now.
If you want to play the VCR, just put the casset and play.
Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
Firstly are you talking terrestrial TV or digital? If you want to record from SAT or Cable connected via scart you will need to select the AV channel that device is connected to. If you want to record through your Aerial make sure it is connected to the video first then out to the TV. At this point you need to post more information about, how and what you are doing. If you are putting your TV onto the channel you want to record and trying to record it, that is not the right way to do it, it IS possible but you dont want to do it that way.
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US.
And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL.
Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV,
Then, again, using the Remote of the TV, select Menu, and then select AUTO in System.
In all likelihood your problem should get solved.
The first thing you need to try is unpluging the unit from the wall totally then wait for about 5 minutes then plug it back in and try again,if you get the same results the cassete is probably stuck in the vcr and that is why the it unit shutsdown.It will continuo to do this until thye cassete is taken out without being force.The unit will need to be service by a professional.
What is the best way to transfer Video cassets to DVD
cannot record vcr to dvd
