Question about AEG Lavamat 88840 Front Load Washer
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water. Water is on, pipe not linked, filters not blocked. Sometimes it does it several tiumes in a row and if I turn a nearby cold tap on and off quickly to give a pulse in the pressure whils it is filling, it starts working OK. Is this indicative of a the main water valve failing? and would it be cured by replacing it please?
    Sniper:
  • 174 Answers
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Posted on Nov 15, 2010
Testimonial: "Very quick & helpful response. I will now follow the advice given."
  • snowman321 Nov 17, 2010
    Accurate disgnosis. I have now bought and installed the part and it is working perfectly again. Incidently, when I enquired at a parts supplier, he recommended using an equivalent part of Qualtax (VAL14) it works fine and is about one quarter the price.
    Thanks again.
  • John Wilkinson Nov 18, 2010
    using non gen parts fine if works. sometimes the coil resistance values vary and can upset the electronics. Glad you fixed it.
My wash-machine, AEG oko lavamat 6955, is blinking at the 1500 and 900 buttons, and is showing the code "F9" and the door will not open. How do I fix this? And if I must have a specalist to...
to clear the error code: whilst holding the pre wash and short wash buttons in together turn the control knob from off to gentle spin, this will clear the fault code and run a LED test. (if all goes weel) F9 means carbon brushes need to be replaced
Nov 06, 2017 | AEG Washing Machines
I have a AEG lavamat 6955 sensorlogic front loader I had the motor changed 5 years ago. The washing machine still works but the drum is tight and does not turn. Even when the machine is off. It is...
Could be that the Inner Drum Spindle is broken, this is a 3 arm spider-ish bracket that holds the inner drum. To test this theory, see if you can lift the inner drum up & down from the door side, you will be able to feel if it is broken.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | AEG L86800 Front Load Washer
Fault code showing, c-d and door light flashes all the time, can't open door and machine starts to wash then stops with above problems. 12 years old, AEG lavamat 74600 also have jsut recently changed the...
When was the last time you changed the brushes on the motor? Check the brushes by removing the motor and then the brushes. The brushes should have at least 15mm left on them. Use compressed air and blow out the motor.
Jan 29, 2018 | AEG Lavamat 72640 Front Load Washer
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Please help
your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer1.gif stops and generates this fault code.
Here are the things to check;
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Feb 07, 2008 | AEG Lavamat 88840 Front Load Washer
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
327 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
